Forum Topic - relearn considered harmful :-): (3 Items)
The io-lbk partition_vfs_relearn() strategy seems kind-of odd.
for (n = 0, part = table; n < PTABLE_NUM_PARTITIONS; ++n, ++part) {
	if (part->os_type == partition->part_info.os_type) {
        /* got a match: copy into "our" partition.
		vfs->vfs_attr.blocksize = rawblk->v_vfs->vfs_attr.blocksize;
The odd part is for the blk-part vfs case (which this is) is that we know the part_index (and nesting level).
So iterating and matching the *very* weak case that our partition id (aka os_type) matches means that you need to have
unique partition ids for each partition or have identically one partition (as would be the case with a dos-thumb drive.)
Wouldn't it make more sense to use the part_index and check to make sure that all the fields are set correctly?  Am I
missing a use-case for this iteration?
dave
RE: relearn considered harmful :-)
Comments below.
> From: dave carlson [mailto:community-noreply@qnx.com]
> Sent: August 5, 2008 10:56 AM
> To: general-filesystems
> Subject: relearn considered harmful :-)
> have unique partition ids for each partition or have
> dos-thumb drive.)
This is the partition relearn handler, so it's running as a result of a
DCMD_BLK_FORCE_RELEARN being sent to /dev/hd0t179 (for example).  That's
why we know the os_type, part_index, etc..  The relearn is, supposedly,
happening because the physical media was removed, and new media
inserted, with a potentially entirely different partition table.  Right
after those lines you've pasted, the code overwrites almost all of the
attributes of the current /dev/hd0t179, with new ones from the partition
table on the media.  The only thing that remains constant is...you got
it...the os_type.
The part_index could move.  All that we know for sure is that
/dev/hd0t179 (to continue the example) has to be os_type 179.  Perhaps
the new media has it on part_index 1, whereas the old media was
part_index 0.
> dave
> http://community.qnx.com/sf/go/post11445
Re: RE: relearn considered harmful :-)
I am getting the relearn from the "feature" of removable devices rmvto=delay from io-blk.
I see how your "interesting" fs-type naming of minors might make this make sense.  However, it seems to me that for the
common-case (ie., the device has not changed) that taking the "first match" will always be wrong if you have a table
with more than one entry of the same fs-type (as is true in my case!)
dave
