Forum Topic - Rhapsody, QNX, and Photon Application Builder: (2 Items)
Hello All,
I am using IBM/Telelogic Rhapsody (v 7.5) together with QNX (v 6.4.1) for a development of a new application. The
application will have a GUI which I would like to create with the Photon Application Builder. Does anyone have
experience developing applications with Rhapsody and PhAB? What is the recommended way to communicate between the two
processes? The User of the application should be able to enter information via the GUI as well as see run time control
data on the GUI. Or is it recommended to program the GUI without the PhAB and to call the Photon library functions
directly from the Rhapsody Model/code? It would be nice to have a solution using the PhAB since it greatly simplifies
the creation of Windows and their layout.
Thank you for you help
Cheers
Marcel
P.S. I posted this thread in the Photon microGUI and General community forum as well since I was not sure where the most
 appropriate place is
Re: Rhapsody, QNX, and Photon Application Builder
Do you use Rhapsody in C or in C++ ?
Code generated by Phab is only C and if you want to connect with it object and classes created in Rhapsody, you will
need to wrap C funtions in a dedicated class.
Another way is to make 2 applications (one generated by Phab, the other by Rhapsody) communicating through share memory
or sockets.
You can also make one on the 2 a library that will be used by the other one.
