Marc Roessler
Problems receiving pulses
Marc Roessler
04/29/2009 12:11 PM
post28365
Hi...
I have some trouble receiving a pulse (on the same node as the sender):
Client (abbreviated):
struct _pulse pulse;
chid = ChannelCreate(0);
coid = ConnectAttach(0, 0, chid, _NTO_SIDE_CHANNEL, 0);
MsgReceive(chid, &pulse, sizeof(pulse), NULL);
Server (abbreviated):
MsgSendPulse (coid, prio, MY_PULSEID, 0);
(with coid the same value as on the client... has been sent to the server before.. cross checked this, value is same as
used on client)
The problem is that the server sends the pulse without throwing an error, but on the client side, MsgReceive() never
returns.
What could possibly go wrong here?
Thanks & Greetings,
Marc
Mario Charest
RE: Problems receiving pulses
Mario Charest
04/29/2009 12:12 PM
post28366
The coid is a per process thing, the server must do a ConnectAttach as well. The pulse probably ends up somewhere else.
> From: Marc Roessler [mailto:community-noreply@qnx.com]
> Sent: April-29-09 12:11 PM
> To: ostech-core_os
> Subject: Problems receiving pulses
> Hi...
> server before.. cross checked this, value is same as used on client)
> error, but on the client side, MsgReceive() never returns.
> Thanks & Greetings,
> Marc
> http://community.qnx.com/sf/go/post28365
Marc Roessler
Re: RE: Problems receiving pulses
Marc Roessler
04/29/2009 12:24 PM
post28367
how would I do this in detail?
Ok, I do a ConnectAttach() on the server.. I need a chid for this.. ok I could create my own channel for that.. and then
send my pulse into that channel.. but how would this reach the client then? Why does the client send me his coid at all
(for example, when sending an event structure to the server) when the server can't do anything with it? Somehow I think
I'm missing an important detail here...
Sean Boudreau(deleted)
04/29/2009 12:27 PM
post28368
then send my pulse into that channel.. but how would this reach the client then? Why does the client send me his coid at
all (for example, when sending an event structure to the server) when the server can't do anything with it? Somehow I
think I'm missing an important detail here...
I think most of the info you're looking for is in the
previous thread on ionotify. The coid and rcvid are
used with MsgDeliverEvent() when the event is SIGEV_PULSE.
You can't use a coid from another process with MsgSendPulse.
Xiaodan Tang(deleted)
RE: RE: Problems receiving pulses
04/29/2009 12:27 PM
post28369
You client, instead of pass the "coid" to ther server, should pass the
"chid, pid" to the server, so the server could "ConnectAttach()" to the
channel the client is going to MsgReceive() on...
But, why is your sever "MsgSendPulse()" to your client? In most the
case, your client suppose to put that coid into a "pulse event", and
send the whole event to the server, and your sever, would
MsgDelieverEvent() it back to let the client know....
-xtang
> Sent: Wednesday, April 29, 2009 12:24 PM
> To: ostech-core_os
> Subject: Re: RE: Problems receiving pulses
> http://community.qnx.com/sf/go/post28367
Marc Roessler
Re: RE: RE: Problems receiving pulses
Marc Roessler
04/30/2009 4:49 AM
post28412
Xiaodan, yes this is true, this would work using MsgDelieverEvent()...
But the problem is that in our case, the server needs to modify a part of the event (the value) before sending it back.
Storing the client-supplied event in the (extended) OCB and modifying it each time before sending it back to the client
is not so elegant...
So I'd rather try to do a MsgSendPulse() "manually".. and also I'd like to get an in depth understanding of what (and
why) is happening internally, and this is a good chance to learn about it.
OK... so if I wanted to use MsgSendPulse myself, the client would send its chid and pid to the server. The nd and the
pid could be read from the ctp struct... is this also contained in the ocb somewhere?
Then I would do on the server:
coid = ConnectAttach( client_nd, client_pid, client_chid, _NTO_SIDE_CHANNEL, NULL);
store this coid, and later:
MsgSendPulse (coid,priority, MY_PULSEID, 0)
correct?
Now what I don't understand: as we just saw, the server needs client nd, pid and chid, in order to do a ConnectAttach()
before sending a Pulse. Then why does the client not include this info in case we use Events (which are noting more than
an abstraction of the above code)? Instead, the client packs his coid (!) into the event structure, and sends this to
the server:
SIGEV_PULSE_INIT( ®_msg.ev, coid, SIGEV_PULSE_PRIO_INHERIT, MY_PULSEID, 0 );
This is what I don't get, and how I got onto the wrong track regarding coid/chid.. If the coid behaves like a file
descriptor (i.e. only makes sense in that specific process), why would the client send it to the server?
And: isn't t the chid process specific as well?
Greetings,
Marc
RE: RE: RE: Problems receiving pulses
04/30/2009 10:29 AM
post28448
Marc,
I understand you confusion in MsgDelieverEvent().
MsgSendPulse() and MsgDelieverEvent() is different.
MsgSendPulse() need a "connection", to sent the pulse; If your server
want to MsgSendPulse() to client, your server need to establish a
connection (via ConnectAttach()) with the client (well, with the
channel created by client). To establish this connection, you need the
"nd, pid, chid", which, you need the client to tell you.
In MsgDelieverEvent case, you don't need a connection "from server to
client", it is the kernel that based on the rcvid, the event type
(PULSE) and the coid inside the event, to find out exactly HOW to
deliver event (in this case, add a pulse into the channel so whoever
MsgReceive() to that channel would get the pulse). Ie, the knowledge
about "pulse event", "connection" ... are all inside the kernel, not
your server application.
This is done so because as you can see, the "event" could be something
else. A signal, an indication of an interrupt... And the server could
designed in a generic way (just MsgDelieverEvent() without knowing
what's in the event), and let the client decided how they want to be
"notified".
Being said that, since a pulse event can carry 32bit "value", and
sometime it is necessary to have server carry back some value to client.
So for a server, knowing (by design) client will only sent "pulse
event", and modify the "pulse value" before MsgDeliever() it back. It
is not so elegant, but I wouldn't say it's
totally wrong.
Hope this making sense now.
-xtang
> Sent: Thursday, April 30, 2009 4:49 AM
> To: ostech-core_os
> Subject: Re: RE: RE: Problems receiving pulses
> back. Storing the client-supplied event in the (extended) OCB
> client is not so elegant...
> learn about it.
> would send its chid and pid to the server. The nd and the pid
> _NTO_SIDE_CHANNEL, NULL); store this coid, and later:
> correct?
> his coid (!) into the event structure, and sends this to the server:
> SIGEV_PULSE_PRIO_INHERIT, MY_PULSEID, 0 ); This is what I
> coid/chid.. If the coid behaves like a file descriptor (i.e.
> Greetings,
> Marc
> http://community.qnx.com/sf/go/post28412
Marc Roessler
Re: RE: RE: RE: Problems receiving pulses
Marc Roessler
04/30/2009 11:14 AM
post28459
Ahh ok now everthing fits in the puzzle...!
I had thought that MsgDeliverEvent was a _user space_ abstraction of the (for example) MsgSendPulse() "syscall" (such as
fread() is for read()...). But as you said, the abstraction is done in the kernel, so the interface can be (and is)
completely different. This makes perfect sense now, and you explained it quite well why this design was chosen.
I changed my code to MsgDeliverEvent, it works just fine now.
Thanks & Greetings,
Marc
