Forum Topic - using HAM to monitor process on remote node.: (2 Items)
I am trying to find out if we can HAM-protect a process in one node by the high availability manager (HAM) in the other
node.  Both the QNX machines are in the same IP network.
Would like to provide further info-
a. I am trying to make my process to self attach to a ham on other node so that i can send heartbeats to it.  I am doing
 a ham_connect_node() call to connect to a remote ham.  This step succeeds.
b. Then, I am using ham_self_attach() to attach to the remote HAM but it is getting attached to a local ham.  I believe
the connection made in step a. should be used in ham_self_attach() and local process should be self attached to remote
HAM.  But, this is not happening, instead the local process gets attached to the local HAM. Since, /proc/ham/entityname
gets created in the local filesystem.  No entityname got created in the remote node.
Is it possible to self attach a local process to a remote HAM? If it is possible, how do I self attach a process in one
node to a ham in other node?
Re: using HAM to monitor process on remote node.
With the code today, it is not possible to self_attach to a remote HAM. Access to
the remote HAM is to monitor remote entities, not to have oneself monitored
remotely.
What are you trying to do?
thanks
shiv
Thu Aug  7 13:24:50 EDT 2008
 --> According to gani koduri <--
doing
	OSTech
	http://community.qnx.com/sf/go/post11511
Shiv Nagarajan,
Kernel Developer, QNX Software Systems,
Ottawa, Canada
