Forum Topic - check for largest free contiguous memory block: (3 Items)
I wonder if there is a lightweight method to check for the largest available contiguous memory block.
I would like to know this value before an application fails with mmap("MAP_PHYS | MAP_ANON") call.
Currently I check it with a tool that tries to allocate contiguous memory blocks with descending size starting with
maximum free memory size until call succeeds. But this has the great constraint that in a running system another process
 that requests contiguous memory at the same time may fail.
The better way would be a call (at kernel or memmgr side) that needn't allocate memory at all.
RE: check for largest free contiguous memory block
  fd = posix_typed_mem_open("sysram", O_RDONLY, POSIX_TYPED_MEM_ALLOC_CONTIG);
  posix_typed_mem_get_info(fd, &info);
  close(fd);
  // contig free size in info.posix_tmi_length
Of course, just because that amount is free at the point of the posix_type_mem_get_info() doesn't mean that a mmap() for
 that amount will succeed - something else could allocate memory between the two calls.
From: Thomas Schickentanz [community-noreply@qnx.com]
Sent: March-31-15 3:33 AM
To: ostech-core_os
Subject: check for largest free contiguous memory block
OSTech
http://community.qnx.com/sf/go/post113646
Re: check for largest free contiguous memory block
Thanks very much!
That is exactly what I am looking for.
