Forum Topic - base address of local apic registers: (2 Items)
hi,
is there anyone who already has experience in using local apic?
i want to use the local apic timer to generate high precision periodic interrupts.
therefor i  have to find out the local apic base address to configure the corresponding registers.
i'm actually using the startup-apic image on a x86 architecture.
many thanks in advance.
Re: base address of local apic registers
HI:
Now I have the same problem with you and I also want to use the APIC timer to generate high precision periodic
interrupts.If you have resolved this problem, could you give me some hints ?
Thanks very much !
