Forum Topic - nano_trace.c - waste of buffer space: (3 Items)
with my first ring mode kernel trace from a 6.4.1 system I was running in a, at first sight, strange thing.
The trace didn't have the expected size.
With ring mode trace you used to have always a kev size of n-kbufs*16KB
This is now changed, I think because of event data truncation at buf end - at least this was a PR we had filed in the
past.
But this change was a hard one.
in nano_trace.c you now switch buffers when there are about 300 slots left.
The problem with this is that I used ring mode tracing as the one with the least system impact for limited systems.
As on these systems I also have low memory conditions, the amount of usable kernel buffers is also low - and remember
each kbuf has to be contigous memory.
So now I am losing 30% of recording time, because buffer space is just not used and I can't just increase num of k-bufs.
what do you think about changeing this threshold to a bit a "smarter" one?
/hp
Re: nano_trace.c - waste of buffer space
> least this was a PR we had filed in the past.
> kernel buffers is also low - and remember each kbuf has to be contigous memory
> /hp
hey ho Mr. Trace (cb) or somebody else
no comments on this?
Sorry HP.
You have a point, but I haven't had a chance to figure out if there
is a "gotcha" lurking in the shadows.
>> /hp
> http://community.qnx.com/sf/go/post41251
cburgess@qnx.com
