Trackers
Trackers
Forum Topic - regcomp() regex.h error codes: (3 Items)
Does anyone know of a reference that explains the error codes for regcomp() as defined in regex.h?
Kevin
AW: regcomp() regex.h error codes
http://www.qnx.com/developers/docs/6.4.0/neutrino/lib_ref/r/regerror.html
regerror() refeers to trunk/lib/c/1a/regerror.c
here you can find the list of error strings
	{ REG_NOMATCH,	"REG_NOMATCH",	"regexec() failed to match" },
	{ REG_BADPAT,	"REG_BADPAT",	"invalid regular expression" },
	{ REG_ECOLLATE,	"REG_ECOLLATE",	"invalid collating element" },
	{ REG_ECTYPE,	"REG_ECTYPE",	"invalid character class" },
	{ REG_EESCAPE,	"REG_EESCAPE",	"trailing backslash (\\)" },
	{ REG_ESUBREG,	"REG_ESUBREG",	"invalid backreference number" },
	{ REG_EBRACK,	"REG_EBRACK",	"brackets ([ ]) not balanced" },
	{ REG_EPAREN,	"REG_EPAREN",	"parentheses not balanced" },
	{ REG_EBRACE,	"REG_EBRACE",	"braces not balanced" },
	{ REG_BADBR,	"REG_BADBR",	"invalid repetition count(s)" },
	{ REG_ERANGE,	"REG_ERANGE",	"invalid character range" },
	{ REG_ESPACE,	"REG_ESPACE",	"out of memory" },
	{ REG_BADRPT,	"REG_BADRPT",	"repetition-operator operand invalid" },
	{ REG_EMPTY,	"REG_EMPTY",	"empty (sub)expression" },
	{ REG_ASSERT,	"REG_ASSERT",	"\"can't happen\" -- you found a bug" },
	{ REG_INVARG,	"REG_INVARG",	"invalid argument to regex routine" },
	{ 0,		"",		"*** unknown regexp error code ***" }
HTH
/hp
>Von: Kevin Miller [mailto:community-noreply@qnx.com]
>Gesendet: Mittwoch, 11. März 2009 20:06
>An: general-community
>Betreff: regcomp() regex.h error codes
>Thanks,
>Kevin
>General
>http://community.qnx.com/sf/go/post24172
RE: regcomp() regex.h error codes
Thanks. I guess I must have missed that page; I was just looking at the source file in /usr/include.
From: Hans-Peter Reichert [mailto:community-noreply@qnx.com]
Sent: Thursday, March 12, 2009 2:47 AM
To: general-community
Subject: AW: regcomp() regex.h error codes
HTH
/hp
>Thanks,
>Kevin
>General
Management Board: Dr. Klaus Blickle (Chairman), Dr. Udo Hüls, Michael Mauser Chairman of the Supervisory Board: Ansgar
. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet. This e-mail may contain
confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in
error) please notify the sender immediately and delete this e-mail. Any unauthorized copying, disclosure or distribution
General
http://community.qnx.com/sf/go/post24196
