wiki3894: Pps_attributes |
Reorganization of PPS attributes for the QNX CAR WebKit Browser#For reference, the previous PPS attributes for the browser are documented here: http://graphics.ott.qnx.com/wiki/index.php/Kaleidoscope_Browser#Flash_HMI_API The two main changes in the new browser PPS object handling are:
When webkit_kd starts, it will use the QNX_COMMAND_OBJ environment variable to determine the location in the filesystem of its PPS control object. For example, the QNX CAR webkit startup script currently sets this environment variable to /fs/pps/qnxcar/external/webkit. In the reorganized system the PPS object named "webkit" would be the control object, and the containing directory "external" would be used for the per-window pps objects. To reduce confusion with other external apps, in the future we may wish to change the location of the PPS control object to something like: /fs/pps/qnxcar/external/webkit/control The following attributes will be used in the control object:#i_defaultClasss_window* c_quit c_ping r_pingResponse The following attributes will be used in the per-window objects:#i_classi_id i_posSize i_visibility i_uri c_loadUri s_posSize r_title Details about each attribute follow:#i_defaultClassparams: <class_name> category: Initial object: control previous attribute: n/a The default window manager class to use for any newly created windows. s_window<suffix> params: <object_name> category: State object: control previous attribute: create_window, param 1 The name of the pps object associated with a WebKit window. This can either be a full path name (starting with '/') or be relative to the directory containing the control object. Note that there may be multiple attributes that start with 's_window' - each refers to a different window. There is an issue of how to come up with unique window names. I recommend to simply base the attribute name suffix on the pps object name, which already needs to be unique. Important: To avoid race conditions, you should wait until webkit_kd has performed the window's creation before deleting the window's PPS object. For example, if you are using the i_uri attribute, you can wait for the creation of the s_loadStatus attribute. c_quit params: none category: Command object: control previous attribute: command::quit of last WebKit window Clean up and exit the webkit_kd process. i_class params: <class_name> category: Initial object: per-window previous attribute: create_window, param 6 The window class associated with the window. If not specified (normal case), the default class from the control object would be used. If neither attribute is set, WebKit would not set the class property of the window (leaving this up to OpenKode). i_id params: <id_string> category: Initial object: per-window previous attribute: create_window, param 6 The window id used to set the io-winmgr id string property. If not specified, WebKit would not set this property (leaving this up to OpenKode). i_posSize params: <x> <y> <width> <height> category: Initial object: per-window previous attribute: create_window, params 2-5 Initial size and position of the browser window. If not specified, information from the class in winmgr.conf will be used by Composition Manager, or Composition Manager will just use full screen. To leave just the position or just the size unspecified, use a value of "-1 -1". i_visibility params: <0|1> category: Initial object: per-window previous attribute: n/a Initial visibility of the window. If not specified, information from the class in winmgr.conf is used (by cm). i_uri params: <uri> category: Initial object: per-window previous attribute: n/a Initial uri to load in the window. Will not be used if s_uri is present and we are restoring a previous state. c_loadUri params: <uri> category: Command object: per-window previous attribute: open_path This command tells the browser to load the given URI. For the final URI of the page after it has finished loading, see the s_uri attribute. c_go params: reload|back|forward|stop|focusNextTypein|focusPrevTypein|close category: Command object: per-window previous attribute: command A series of simple browser commands that need no parameter. This attribute will only be used once on a delta basis, i.e. it is not a state attribute.
params: [<number>] category: Command object: per-window previous attribute: zoom_in Increase the zoom factor for HTML layout by the given percentage. The default is 25%. The actual resulting zoom percentage will be written into the s_zoomPercent attribute by WebKit. c_zoomOut params: [<number>] category: Command object: per-window previous attribute: zoom_out Decrease the zoom factor for HTML layout by the given percentage. The default is 25%. The actual resulting zoom percentage will be written into the s_zoomPercent attribute by WebKit. c_zoomPercent params: <number> category: Command object: per-window previous attribute: zoom_percent Command to set the zoom factor of the browser window. The normal zoom is 100. c_ping params: none category: Command object: per-window previous attribute: ping Check if WebKit is processing attribute changes for the PPS object. This can be used on the control object or the per-window PPS objects. See also the r_pingResponse attribute. c_modalDialog params: <type_number> <dialog_text> category: Command object: per-window previous attribute: n/a This is currently the only command attribute created by WebKit for the HMI. It gives the HMI information on creating alert, confirm and prompt dialogs. The type numbers for these are 0, 1 and 2 respectively. s_posSize params: <x> <y> <width> <height> category: State object: per-window previous attribute: scrn_prop The current position and size of the browser window (i.e. destination viewport). WebKit will update this attribute as well as respond to changes. s_visibility params: <0|1> category: State object: per-window previous attribute: scrn_enable The current visibility of the browser window. WebKit will update this attribute as well as respond to changes. s_requestedUri params: <uri> category: State object: per-window previous attribute: n/a The URI that the browser was asked to load. For the final URI of the page after it has successfully finished loading, see the s_uri attribute. WebKit will update this attribute whenever it starts to load the main frame of a web page. For example, this attribute will contain the URI that WebKit was asked to load whenever the user selects a link, presses the "back" button, etc. s_uri params: <uri> category: State object: per-window previous attribute: url The uri of the last web page to be loaded (and should still be displayed) in the browser window. WebKit will update this attribute after a page loads. WebKit may use this attribute to restore a previous state. WebKit will not respond to changes in this attribute - see the c_loadUri attribute. s_loadStatus params: started|progress|finished|error|finished_with_error|cancelled <percent>|<error_msg> category: State object: per-window previous attributes: start, progress, complete, info 0 This attribute is used for a series of responses to the HMI to tell it about the status of web page loading. The 3 possible values are:
params: <number> category: State object: per-window previous attribute: n/a The current zoom factor of the browser window in percent. The normal zoom is 100. r_title params: <title_string> category: Response object: per-window previous attribute: title This is a response to the HMI containing the title of the web page currently loading or just loaded. r_info params: <info_type> <info_message> category: Response object: per-window previous attribute: info 1,2 This is a response to the HMI containing status messages and hover-over-link text. The type numbers for these are 1 and 2 respectively. r_virtualKeyboard params: <action_code> category: Response object: per-window previous attribute: virtual_keyboard This is a response to the HMI that the virtual keyboard should be opened or closed. It also contains information on whether this is a password field being opened . The codes for these 3 actions are 1, 0 and 2 respectively. r_pingResponse params: [modal] category: Response object: per-window previous attribute: ping_response This is a response to the HMI that a c_ping attribute change was received. If webkit event loop processing is in a modal state, the word "modal" will be set as the attribute's value. Otherwise the value will be blank. r_dialogResponse params: <result_number> <prompt_response> category: Response object: per-window previous attribute: n/a This is a response from the HMI to WebKit that the user has completed a modal dialog such as the javascript alert, confirm or prompt. It will contain information on whether the user pressed OK or CANCEL (result numbers 1 and 0 respectively), and the prompt string they entered (if any). |
