wiki3058: Nto640FreescaleMpc8360eMdsTrunkReleasenotes (Version 2)
Release Notes for the QNX Neutrino 6.4.0 BSP for Freescale MPC8360E MDS trunk#
System requirements#
Target system#
  • QNX Neutrino RTOS 6.4.0
  • Board version: Freescale MPC8360E MDS
  • ROM Monitor version U-Boot 1.3.0-rc2
  • 32M flash
  • 256MB DDR RAM
Host development system#
  • QNX Momentics 6.4.0, one of the following host systems:
    • QNX Neutrino 6.4.0
    • Microsoft Windows Vista, XP SP2 or SP3, 2000 SP4
    • Linux Red Hat Enterprise Workstation 4 or 5, Red Hat Fedora Core 6 or 7, Ubuntu 6.0.6 LTS or 7, or SUSE 10
  • Terminal emulation program (Qtalk, Momentics IDE Terminal, tip, HyperTerminal, etc.)
  • RS-232 serial port
  • NULL-modem serial cable
  • Ethernet link
System layout#
The table below depicts the memory layout for the image and for the flash.
Memory layout
ItemAddress
OS image loaded at: 0xfe700000
IPL location: 0xfef00000
Flash base address 0xfe000000
Getting Started#
Step 1: Connect your hardware#
Connect the serial cable to the first serial port of the MPC8360E MDS board to the first serial port of your host machine (e.g. ser1 on a Neutrino host).
  • If you have a Neutrino host with a serial mouse, you may have to move the mouse to the second serial port on your host, because some terminal programs require the first serial port.
Step 2: Build the BSP#
You can build a BSP OS image from the source code or the binary components contained in a BSP package. For instructions about building a BSP OS image, please refer to the chapter Working with a BSP in the Building Embedded Systems manual.
Step 3: Transfer the OS image to the target#
Boot OS images by ROM monitor#
1. On your host machine, start your favorite terminal program with these settings:
  • Baud: 115200
  • Bits: 8
  • Stop bits: 1
  • Parity: none
  • Flow control: none
2. Setting up the environment
  • Apply power to the target board. You should see the U-Boot ROM monitor output.
  • You can use TFTP download (the default) to transfer an OS image to the board, as described below.
This method requires a raw image, which the buildfile creates by default.
On your target, type the following, filling in the appropriate IP addresses and ifs file:
=> setenv ipaddr 192.168.200.2
=> setenv serverip 192.168.200.1
=> setenv bootfile ifs-mpc8360mds.raw
=> setenv loadaddr 0x200000
=> setenv bootcmd 'tftpboot $loadaddr $bootfile; go $loadaddr'
=> setenv bootdelay 2
=> saveenv
Saving Environment to Flash...
Un-Protected 1 sectors
Erasing Flash...
flash erase done
Erased 1 sectors
Writing to Flash... done
Protected 1 sectors
=> boot
At this point you should see the ROM monitor download the boot image, indicated by a series of number signs. You'll also see output similar to this when it completes downloading:
geth: PHY is Marvell 88E11x1 (1410cc2)
FSL GETH0: Full Duplex
FSL GETH0: Speed 1000BT
FSL GETH0: Link is up
Using FSL GETH0 device
TFTP from server 192.168.200.1; our IP address is 192.168.200.2
Filename 'ifs-mpc8360emds.raw'.
Load address: 0x200000
Loading: #################################################################       #################################################################
done
Bytes transferred = 819804 (c825c hex)
## Starting application at 0x00200000 ...
You should see the QNX Neutrino welcome message on your terminal screen:
Welcome to QNX Neutrino trunk on the Freescale MPC8360E MDS board
Using the QNX IPL code#
1. Flashing the IPL and the OS image
  • The images directory contains a mkflash script that creates a 32 MB binary flash image that contains the IPL and the OS image. The IPL is stored at flash offset 0x0 and 0x1F000000, so that the board can boot low and high. Th OS-image is stored at at offset 0x1000000. The IPL's default behavior is to scan the flash strarting at flash offset 0x1000000 for an OS image. The flash image can be loaded to the flash using a flash programmer.
  • If your MPC8360E MDS board has u-boot installed, then both the IPL and the OS image can be loaded to RAM using tftpboot, then copied to the flash. For example, you could have u-boot stored at the bottom of the flash and the IPL at the top. Here is an example of how to use u-boot to write the IPL and OS image to the flash:
    erase fff00000 ffffffff
    tftpboot 200000 ipl-mpc8360e
    cp.b 200000 fff00000 8000
    erase ff000000 ff1fffff
    tftpboot 200000 ifs-mpc8360emds.raw
    cp.b 200000 ff000000 200000
Note: High/Low boot is configured via the BMS bit in the Reset Configuration Word (RCW). The RCW can be read from offset 0 of the flash or from the on-board FPGA. Please read the board documentation for more details.
2. Using IPL
Note: This section assumes that the IPL has already been flashed into the CPU card.
Causion: This method requires an binary image. You have to modify the buildfile to create this format. Change this:
[virtual=ppcbe,raw]
to this:
[virtual=ppcbe,binary]
Rename ifs-mpc8360emds.raw to ifs-mpc8360emds.bin in images/Makefile, and then rebuild the image.
  • After you apply power to the board, the IPL will run and you should see the following message on your host screen:
    Welcome to QNX Neutrino on the Freescale MPC8360E MDS board
    Hit 'd' to download a Neutrino image with sendnto
    Press any other key to boot from flash
  • Press d to transfer the OS image over the serial link.
Note: Pressing any other key would tell the IPL to boot OS image from flash. This assumes that the OS image has already been copied into the flash.
  • Copy the OS image from your host to the target using this command:
    On a Windows host:
            sendnto -b115200 -dCOM1 ifs-mpc8360emds.bin
    On a QNX Neutrino host:
            sendnto -b115200 -d/dev/ser1 ifs-mpc8360emds.bin
    On a Linux host:
	    sendnto -b115200 -d/dev/ttyS0 ifs-mpc8360emds.bin
    You should now see the Neutrino welcome message on your terminal screen:
   Welcome to QNX Neutrino 6.3 on the Freescale MPC8360E MDS board
Step 4: Start working with Neutrino OS#
   You can now test the OS simply by executing any shell builtin command or any command residing within the OS image (e.g. ls).
   Once the initial image is running, you can update the OS image using the network and flash drivers. For sample command lines, please see the " Driver Command Summary" section.
Creating a flash partition#
1. Enter the following command to start the flash filesystem driver:
      devf-generic -s0xFE000000,32M
2. To prepare the area for the partition, enter the following command:
      flashctl -p/dev/fs0 -o0 -l6M-ve
3. Format the partition:
      flashctl -p/dev/fs0p0 -o0 -l6M-vf
4. Slay, then restart the driver:
      slay devf-generic
      devf-generic -s0xFE000000,32M;
You should now have a /fs0p0 directory where you can copy files to.
Driver Command Summary#
The driver command lines below are specific to the Freescale MPC8360E MDS board. See the online docs for each driver for additional command-line options and other details.
NOTE: Some of these drivers are commented out in the default buildfile. To use the drivers in the target hardware, you'll need to uncomment them in your buildfile, rebuild the image, and load the image into the board.
ComponentBuildfile CommandRequired BinariesRequired LibrariesSource Location
Startup startup-mpc8360e . . src/hardware/startup/boards/mpc8360e
Serial devc-ser8250 -e -F -c264000000 -b115200 0xe0004500,0x09 0xe0004600,0x0Adevc-ser8250 . src/hardware/devc/ser8250
PCI pci-mpc83xx pci-mpc83xx
pci
. src/hardware/pci/mpc83xx
Network io-pkt-v4 -ducc_ec-mds mac=00e02991234c,channel=1,phy=0,mode=GMII -ptcpipio-pkt-v4
ifconfig
devn-ucc_ec-mds.so
libsocket.so
devnp-shim.so
src/hardware/devn/ucc_ec/ppc/mds.dll.be
I2C i2c-mpc5200 -p0xe0003000 -c88000000 -i14 --u1 (Channel 1)
i2c-mpc5200 -p0xe0003100 -c88000000 -i15 --u0(Channel 2)
i2c-mpc5200 . src/hardware/i2c/mpc5200
Known Issues for this BSP#
  • The IPL included in this BSP release is compatible only with the MPC8360EA-MDS-PB (board revision Pilot) version of the development platform. It has been tested under the following configurations:
     MPC8360E silicon rev. 2.1
     Board assembly rev. 0.51
     Factory preset switches
     256 MB DDR2 SO-DIMM pugged into U33
  • The BSP's src/hardware/devn/ucc_ec directory contains a README file outlining the specific limitations of the network driver.
  • Don't rename the directory after running setupbsp, or else you won't be able to build or uninstall the BSP properly. (QNX Ref# 38361)
  • If you uninstall this BSP, the uninstaller removes only those files that were originally shipped with the BSP (whether or not you modified them). If you've added any files, they remain on your system. (QNX Ref# 38368)
  • The uninstaller script doesn't remove itself when you uninstall the BSP. (QNX Ref# 38368)
  • If you install a BSP more than once, and then uninstall an instance of it, the documentation for all copies of the BSP is uninstalled. (QNX Ref# 38320)
  • You can not use the second network interface. (QNX Ref# 63723)
  • All QNX BSPs ship with an images/Makefile whose purpose is to build an image filesystems (ifs) file using drivers built from source. Currently, it's set up to copy buildfiles from within the source directory structure (source/hardware/startup) to the images directory so that it can generate an ifs. This happens automatically when you do a top-level make, but this mechanism doesn't work when you're making an binary BSP. (QNX Ref# 38242)
Workaround: For a binary-only BSP, change these lines in the root Makefile:
all: install links $(if $(wildcard images/*),images) @echo done
