wiki2775: Nto640FreescaleI.mx31AdsTrunkReleasenotes (Version 1) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Release Notes for the QNX Neutrino 6.4.0 BSP for Freescale i.MX31 ADS Trunk#
System requirements#Target system
Host development system
System Layout#The tables below depict the memory layout for the image and for the flash.Memory layout
Flash layout
The interrupt vector table can be found in the buildfile located at src/hardware/startup/boards/imx31/build
Getting Started#Starting Neutrino#Step 1: Build the BSP Copy or transfer the IFS image into your tftp server's directory.
Step 2: Connect your hardware
Then, apply power to the target. You should see output similar to the following: ++... Read from 0x07ee0000-0x07f00000 at 0xa1fe0000: . ... Read from 0x07ed3000-0x07ed4000 at 0xa1fff000: . Clock input is 27 MHz Booting from [NOR flash] Ethernet eth0: MAC address 00:01:02:03:03:04 IP: 10.42.103.53/255.255.0.0, Gateway: 10.42.98.230 Default server: 10.42.98.230 RedBoot(tm) bootstrap and debug environment [ROMRAM] Non-certified release, version FSL 200631 - built 15:19:21, Aug 25 2006 Platform: MX31 ADS (Freescale i.MX31 based) PASS 1.1 [x32 DDR] Copyright (C) 2000, 2001, 2002, 2003, 2004 Red Hat, Inc. RAM: 0x00000000-0x07f00000, [0x00013f00-0x07ed1000] available FLASH: 0xa0000000 - 0xa2000000, 256 blocks of 0x00020000 bytes each. RedBoot> Step 3: Setup the environment At the RedBoot prompt, issue the fconfig command to change the current environment. The current configurations will be displayed; change the configuration if you want. Run script at boot: false Use BOOTP for network configuration: false Gateway IP address: 10.42.98.230 Local IP address: 10.42.103.53 Local IP address mask: 255.255.0.0 Default server IP address: 10.42.98.230 Board specifics: 0 Console baud rate: 115200 Set eth0 network hardware address [MAC]: true eth0 network hardware address [MAC]: 0x00:0x01:0x02:0x03:0x03:0x04 GDB connection port: 9000 Force console for special debug messages: false Network debug at boot time: false Update RedBoot non-volatile configuration - continue (y/n)? Type y to accept the new configuration; RedBoot will write the new configuration to the flash. Step 4: Boot the IFS image Once the above setup is complete, you can run the load command at the RedBoot prompt to download the image: load -r -b 0x00100000 /xfer/ifs-mx31ads.raw RedBoot will display the follow message and start downloading the boot image: Using default protocol (TFTP) If the image is successfully loaded RedBoot will display: Raw file loaded 0x00100000-0x002300d3, assumed entry at 0x00100000 Type run 0x00100000 to jump to startup and boot the IFS image. You should see the QNX Neutrino welcome message on your terminal screen: Welcome to Neutrino on the i.MX31ADS (ARM 1136 core) Board You can test the OS simply by executing any shell builtin command or any command residing within the OS image (e.g. ls). Once the initial image is running, you can update the OS image using the network and flash drivers. For sample command lines, please see the "Summary of driver commands" section.
Writing the OS image into the Flash using RedBoot#RedBoot is located at the first megabyte offset in flash (i.e. 0xA0000000). The last 128 KB are reserved for RedBoot's configuration data. In the following example, we store a Neutrino boot image of up to 3 MB immediately after RedBoot (at the offset 0xA0100000). From the RedBoot> prompt, follow the following procedure to transfer the OS image to the target memory and burn it into flash: 1. Transfer the OS image to RAM, at the RedBoot> prompt: load -r -b 0x00100000 /full_path_to_image/ifs-mx31ads.raw 2. Erase the flash from the offset 1 MB to the offset 4 MB: fis erase -f 0xa0100000 -l 0x00300000 3. Copy the OS image from RAM (0x00100000) to flash (0xa0100000): fis write -f 0xa0100000 -b 0x00100000 -l 0x00300000 4. Now you can load the OS image directly from flash on power on, as follows: mcopy -s 0xa0100000 -d 0x00100000 -l 0x00300000 run 0x00100000
Creating a flash partition#1. Start the NOR flash filesystem driver by issuing the devf-mx31ads command at the ksh prompt, or in the startup script.2. Prepare the area for the partition. Because the ROM monitor and IPL/OS image are in the first 4MB of flash, you will not want to erase them. Use the -l (length) and -o (offset) options to avoid these areas. Assuming that the ROM monitor and IPL/OS image have a maximum size of 4 MB and we want to create a 16 MB partition: flashctl -p/dev/fs0 -o4M -l16M -ve 3. Format the partition: flashctl -p/dev/fs0p0 -o4M -l16M -vf 4. Slay, then restart the driver: slay devf-mx31ads devf-mx31ads In this example, you have a 16 MB flash partition starting at the end of the OS image (4 MB offset). You should now have a /fs0p1 mount on the target to which you can copy files.
Some of the drivers are commented out in the default buildfile. To use the drivers in the target hardware, you'll need to uncomment them in your buildfile, rebuild the image, and load the image into the board. Startup, USB, Graphics and Audio have addtional details: Startup#startup-mx31ads [startup-options] Some modules are not enabled by default on power up, so you need to use command-line options to startup to enable them. These options must be passed before any other startup options.
USB#USB can be run either on the USB HOST Serial Interface (FS/LS) or the USB HOST ULPI Interface (HS), which are referred to as Host 1 and Host 2 respectively.To use Host 1:
The USB host port is j5. To use Host 2:
Note:
In order to use Host 2, The ATA module must be disabled and the NAND flash card must be removed . The USB host port is j4. You will want to include class drivers, such as devb-umass in order to make use of attached USB devices. Graphics:#See the startup section above for the correct startup arguments. To start the driver. io-display -dvid=0,did=0 Note: Starting io-display simply starts the display server. Nothing will appear on the display until a graphical application is run (i.e. vsync or egl-gears-lite). Required Config Files:
The /etc/system/config/display.conf configuration file describes the graphics memory interface settings. It should contain the following for a 240x320 resolution: device { drivername=imx31 vid=0 did=0 display { xres=240 yres=320 refresh=60 pixel_format=rgb565 } } Audio #
Note:
Only playback is supported To enable audio, ensure that the MC13783 board has the following switch settings: S8 1: OFF, 2: OFF, 3: ON, 4: OFF, 5: OFF, 6: OFF S7 1: OFF, 2: OFF, 3: OFF, 4: OFF, 5: ON, 6: ON Then in the build file, launch the sdma configuration utility, mx31_dma_cfg -c, and the SPI driver before starting io-audio. The stereo output jack is located at J2.
Known Issues#
The following issues have been resolved with the 2.0.0 release:
