wiki2330: AtmelAT91SAM9263EKEvaluationBoard (Version 11)
Atmel At91sam9263 EK Board Support Package#
This BSP supports the Atmel At91sam9263 EK Board.
Access to this BSP is granted on-demand, please first contact the QNX Community Management Group_
Releases#
QNX Neutrino Trunk#
Date Version Prerequisites Installation Notes Release Notes License(s) Support Provider Download Source Tag
Latest trunk QNX Momentics Trunk Trunk Generic Notes here Restricted Apache II Experimental QNX Coming Soon! Coming Soon!
QNX Neutrino 6.4.0#
Latest trunk QNX Momentics 6.4.0 6.4.0 Generic Notes here Restricted Apache II Experimental QNX Coming Soon! Coming Soon!
QNX Neutrino 6.3.2#
2008-06-30 1.0.0 QNX Momentics 6.3.2 6.3.2 Generic Notes included in archive Restricted Apache II Experimental QNX Project Downloads none
Features#
Feature Planned Availability Format Notes
Audio Completed SRC .
I2C Completed SRC .
IPL Completed SRC “Cold Start” IPL, programmed to Dataflash(Serial Flash)
SD Block Completed SRC .
Serial Completed SRC Supporting DB9 RS232 connectors, serial UART and DBGU UART modes of operation.
Ethernet Completed SRC 10/100Mbit/s
SPI Host Completed SRC .
SPI Slave Completed SRC .
Startup Completed SRC .
USB Completed BIN QNX SPD 6.4.x (Binary Only)
Some of these drivers are commented out in the default buildfile. To use the drivers in the target hardware, you'll need to uncomment them in your buildfile, rebuild the image, and load the image into the board.
QNX Neutrino Trunk Change History#
Trunk#
  • Same as QNX Neutrino 6.4.0 for Atmel At91sam9263 EK Trunk
QNX Neutrino 6.4.0 Change History#
Trunk#
  • Created from QNX Neutrino 6.3.2 BSP for Freescale i.MX27 ADS 1.0.0
  • Built using the latest 6.4.0 toolchain
  • Photon Graphics Driver do not include
QNX Neutrino 6.3.2 Change History#
1.0.0#
  • Initial release under Restricted Apache II
  • Includes:
    • Audio
    • Ethernet
    • I2C
    • IPL
    • SD Block
    • Serial
    • SPI Host
    • SPI Slave
    • Startup
    • USB (included with OS)
    • Photon Graphics Driver, 2D Acceleration with blitting, polygon fill, line drawing.
NOTE: This software may not be used in, licensed for use with or otherwise distributed for use with oxymeter products.
Search Keywords: at91sam9263, at91sam9263-ek, at91sam, evm, Atmel, AT91SAM9263, AT91SAM9263-EK, AT91SAM, EVM
