| wiki5313: Nto650TiOmap3530BeagleTrunkReleasenotes | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Release Notes for the QNX Neutrino 6.5.0 BSP for OMAP3530 Beagle Board#System requirements#Target system#
Host development system#
The interrupt vector table can be found in the buildfile located at src/hardware/startup/boards/omap3530/beagle.build Getting Started#Step 1: Connect your hardware#
Step 2: Build the BSP#You can build a BSP OS image from the source code or the binary components contained in a BSP package. For instructions about building a BSP OS image, please refer to the chapter Working with a BSP in the Building Embedded Systems manual.Step 3: Transfer the OS image to the target using the ROM monitor#On your host machine, start your favorite terminal program with these settings:
Setting up the environment#For OMAP3530 Beagle Board#Apply power to the target board. You should see output on your terminal console, similar to the following: Texas Instruments X-Loader 1.4.2 (Feb 19 2009 - 12:01:24) Reading boot sector Loading u-boot.bin from nand U-Boot 1.3.3 (Jul 10 2008 - 16:33:09) U-Boot 2009.01-dirty (Feb 19 2009 - 12:22:31) I2C: ready OMAP3530-GP rev 2, CPU-OPP2 L3-165MHz OMAP3 Beagle board + LPDDR/NAND DRAM: 256 MB NAND: 256 MiB MUSB: using high speed In: serial usbtty Out: serial usbtty Err: serial usbtty Board revision C Serial #7842000300000000040323090b017014 Hit any key to stop autoboot: 0 OMAP3 beagleboard.org # SD card download#OMAP3 beagleboard.org # mmcinit; fatload mmc 0 0x80100000 ifs-omap3530-beagle.bin; go 80100000 At this point you should see the ROM monitor download the boot image, indicated by a series of number signs. You'll also see output similar to this when it completes downloading: OMAP3 beagleboard.org # mmcinit; fatload mmc 0 0x80100000 ifs-omap3530-beagle.bin; go 80100000 reading ifs-omap3530-beagle.bin 6198048 bytes read ## Starting application at 0x80100000 ... Beagle Board Revision: c3 CPU0: L1 Icache: 256x64 CPU0: L1 Dcache: 256x64 WB CPU0: L2 Dcache: 4096x64 WB CPU0: VFP-d32 FPSID=410330c1 CPU0: NEON MVFR0=11110222 MVFR1=00011111 CPU0: 411fc083: Cortex A8 rev 3 600MHz Loading IFS...decompressing...done System page at phys:80010000 user:fc404000 kern:fc404000 Starting next program at vfe04e604 cpu_startnext: cpu0 -> fe04e604 VFPv3: fpsid=410330c1 coproc_attach(10): replacing fe07e01c with fe07d8bc coproc_attach(11): replacing fe07e01c with fe07d8bc Welcome to QNX Neutrino 6.5.0 on the Texas Instruments OMAP3530 (ARMv7 Cortex-A8 core) - Beagle Board Now you can test the OS, simply by executing any shell builtin command or any command residing within the OS image (e.g. ls).
Flashing the IPL on to the target#Step A: Create the IPL image#Run the mkflashimage script, inside the /images directory of the BSP. The output file from this script is a binary IPL image called ipl-omap3530beagle.bin and nand-ipl-omap3530beagle.bin.First, you'll download ipl-omap3530beagle.bin file to the board's memory using the pserial tools, and then you can burn the ifs image ifs-omap3530-beagle.bin and NAND IPL image nand-ipl-omap3530beagle.bin into the board's NAND flash. The IPL is padded to 24K. The following steps describes how to generate the ipl-omap3530evm.bin and nand-ipl-omap3530beagle.bin:
#!/bin/sh
# script to build a binary IPL and boot image for the OMAP3530 Beagle board
set -v
# Convert IPL header into Binary format
${QNX_HOST}/usr/bin/ntoarmv7-objcopy --input-format=elf32-littlearm --output-format=binary ../src/hardware/ipl/boards/omap3530beagle/arm/le.v7/boot_header.o ./tmp-boot-header.bin
# Convert IPL into Binary format
${QNX_HOST}/usr/bin/ntoarmv7-objcopy --input-format=elf32-littlearm --output-format=binary ../src/hardware/ipl/boards/omap3530beagle/arm/le.v7/ipl-omap3530beagle ./tmp-ipl-omap3530beagle.bin
# Cat boot header and ipl together
cat ./tmp-boot-header.bin ./tmp-ipl-omap3530beagle.bin > ./tmp-header-ipl-omap3530beagle.bin
# Pad Binary IPL to 24K image, this is the image used by boot from UART
mkrec -s24k -ffull -r ./tmp-ipl-omap3530beagle.bin > ./ipl-omap3530beagle.bin
# Pad Binary IPL with Header to 24K image, this is the image to put on NAND and boot from NAND
mkrec -s24k -ffull -r ./tmp-header-ipl-omap3530beagle.bin > ./nand-ipl-omap3530beagle.bin
# clean up temporary files
rm -f tmp*.bin
echo "done!!!!!!!"
Step B: Booting an IPL image#Refer to the AM/OMAP Boot Resource Pages for options for installing the IPL to flash. Creating a new flash partition#
You should now have a /fs/etfs directory which you can copy files to.
Summary of driver commands#The following tables summarize the commands to launch the various drivers. For the OMAP3530 Beagle board #
Some of the drivers are commented out in the default buildfile. To use the drivers in the target hardware, you'll need to uncomment them in your buildfile, rebuild the image, and load the image into the board. Startup #Command:startup-omap3530 -L 0x87E00000,0x200000 -v -D8250.0x49020000^2.0.48000000.16 beagle SD card #Command:resource_seed i2c-omap35xx pmic_tw4030_cfg devb-mmcsd-beagle cam quiet blk cache=2mNote: To start the SD driver, you'll need to execute resource_seed, the I2C driver and pmic_tw4030_cfg utility first Audio#Command:resource_seed i2c-omap35xx pmic_tw4030_cfg io-audio -domap35xx-twl4030 wave testfile.wavNote: To start the audio driver, you'll need to execute resource_seed, the I2C driver and pmic_tw4030_cfg utility first Graphics#Command: i2c-omap35xx pmic_tw4030_cfg io-display -dvid=0,did=0Note: To start the graphics driver, you'll need to execute the I2C driver and pmic_tw4030_cfg utility first USB OTG Host Controller driver#Command: io-usb -domap3530-mg ioport=0x480ab000,irq=92 -dehci-omap3 ioport=0x48064800,irq=77,verbose=5 Note: 1. Min A to min B usb cable is required. 2. Connect to the micro usb adapter as we do not support the larger one yet. 3. Press and hold the S1 (User) button at power up or reset until board starts booting (~1 sec). 4. May need to power cycle board to get S1 (User) button working depending on how/if the power management chip has been reconfigured. 5. Start io-usb with the stock options from the bsp build file. SGX Graphics Accelerator driver#Command:In build file: #GRAPHICS_ROOT=/usr/lib/graphics/omap3530 #/usr/lib/graphics/omap3530/pvrsrvd #gles1-egl-gears & In command line: #export GRAPHICS_ROOT=/usr/lib/graphics/omap3530 #cd /usr/lib/graphics/omap3530/ #pvrsrvd ## validate application #gles1-egl-gears & Note: 1. io-display have to run first 2. The Composition_Manager patch-650-2258-CompMgr.tar need be installed first.
# cd beagle_workdir
# tar -xvf patch-650-2258-CompMgr.tar
# cd patches/650-2258/target/qnx6
# cp -r armle-v7 ../../../../prebuilt/
# cd beagle_workdir
# make clean all
WiFI driver #Command:
## WIFI start ram filesystem
devb-ram ram capacity=16384,nodinit,cache=0m
waitfor /dev/hd0
fdisk /dev/hd0 add -t 6
mount -e /dev/hd0
mkdosfs /dev/hd0t6
mount -t dos /dev/hd0t6 /fsram
## SDIO WIFI driver
## Note: please insert SDIO WIFI card. and then run ". ./root/wifi.sh"
/root/wifi.sh
io-pkt-v4 -d /proc/boot/devnp-mv8686.so dir=/root/io-pkt,verbose=1,poll=0 -p tcpip mclbytes=4096,stacksize=65000 random
ifconfig mv0 up
wpa_supplicant -Dwext -imv0 -C /fsram/tmpfs &
wpa_cli -i mv0 -p /fsram/tmpfs
Note: 1. Because SD and SDIO wifi cards using the same slot, please slay the SD driver first before running the SDIO wifi driver. 2. Please refer to WIFI_HOW_TO_RUN.txt which is included in the BSP to setup the wifi connection in wpa_cli cmmand line. 3. Please refer to QNX document:WiFi Configuration Using WPA and WEP. Edit /etc/wpa_supplicant.conf file in build file to configure the wifi connection.
Known issues for this BSP#
