| wiki4358: SDP_6.5.0_BSP_Info | ||
SDP 6.5.0 BSP Information#This page contains important information required to compile and package BSPs with the QNX Software Development Platform 6.5.0.
6.5.0 Interoperability #Building 6.4.x BSPs with QNX SDP 6.5.0#6.4.x BSPs should compile and work with QNX SDP 6.5.0. Below are the known generic issues with 6.4.x bsps. The release notes for the specific bsps will also be updated with specific known issues for that bsp. Please get the latest release notes for your bsp before attempting to compile it with SDP 6.5.0.Some 6.4.x BSPs contain old versions of some header files which are included in the SDP 6.5.0. If you get compile errors in these files, try removing the files from the BSP itself and recompiling:
Due to compiler changes, some 6.4.x BSPs contain source files that no longer compile. Some errors and solutions are listed below:
--- trunk/hardware/startup/boards/edosk7780/init_cpuinfo.c 2009/04/08 01:47:35 217585 +++ trunk/hardware/startup/boards/edosk7780/init_cpuinfo.c 2009/06/01 14:04:50 222170 @@ -42,6 +42,7 @@ "or %3, %0;\n" \ "jmp @%0;\n" \ "nop;\n" \ + ".align 2\n" \ ".La%=:\n" \ "mov.l %2, @%1;\n" \ "nop;\n" \
libi2c-master.a compatibility issues:
BSP's not compatible with 6.5.0:
ARM V7 support#Changing the variant of a BSP to V7 is not support since any binaries included in that BSP is not compatible with V7. Look for an updated 6.5.0 BSP for your platform here. Building 6.5.0 BSPs with QNX SDP 6.4.x#This is not supported, and upgrading to SDP 6.5.0 is required.
Available BSPs#A complete list of BSPs can be found here.
