wiki2979: F27DetailedDesign
- Getting list of F27 packages#
Data Provider#
  • The data provider uses a package definition file hosted on F27 to get the list of packages
Package definition file#
  • Similar to a memento. It contains packages details including:
    • Title - name of the package
    • Release - package version
    • CPU - target CPU variant
    • Source dependency - Reference to the dependent packages
    • Containing projects - Reference to
    • Vendor - package provider (mainly QNX)
    • Repository - The F27 repository (e.g. http://community.qnx.com/svn/repos/coreos_pub)
    • Location - the F27 hosting URL within the repository (e.g. trunk/services/system)
    • Description - the package detailed description
  • The definition file will be maintained by F27 admin (?)
  • The file is publicly accessible, can be downloaded without authentication. Location of the file is - TBD
  • The IDE does not cache any package information locally but always queries the definition file at the beginning of every new import section
How packages are defined?#
  • What is the granularity?
  • Source or binary format?
  • Make sure packages are build-able before posting?
F27 login credential - two scenarios#
A per-repository login prompt#
  • Similar to the update manager login panel
  • User can have different username and password on different repositories (possible?)
  • Username and password are recorded to "Team -> SVN -> Password Management" for future re-use
A preference page to save login username and password#
  • Applicable when using the same login info for all repositories
  • Has to encypt the password. Leverage the platform "Secure Storage" mechanism (?)
  • Still has limitation - save in workspace only. Can it be exported to other workspace?
Package dependencies#
  • Dependencies are defined in the "module.tmpl" <requires> tab, example for "trunk/services/system" is:
	<!-- Dependencies -->
	<requires>
		<part build="false" location="lib/elf"/>
		<part build="true"  location="lib/c"/>
		<part build="false" location="hardware/startup/lib"/>
		<part build="false" location="utils/m/mkasmoff"/>
	</requires>
  • To build the complete dependency, all the referenced packages' module.tmpl files have to be fetched locally and parsed
  • At this phase, only module.tmpl files are fetched, not the whole package tree
- Presenting packages#
The model#
Refactor existing model#
  • Abstract the existing "PackageContainer" model to a "globalPackageContainer"
  • Refactor current source zip file model to be one implementation of the "globalPackageContainer"
  • Create a new remote package model as another implementation of the "globalPackageContainer"
  • Refactor all the model classes (BSP, sourcePackage) using the same manner
The remote package model#
  • The remote package model is an abstract model by itself with different implementation for remote binary file and remote source tree
  • Based on the contents of the package definition file and the package dependency hierarchy, the remote package model is built as a tree like structure
  • Each tree node is represented by a "packageItem" class. It has properties like "title", "release", "cpu", "repositoryLocation", "dependingOn", "dependedBy", "enabled", etc. There are helper methods to get/set properties
  • A "packageManager" class holds the model objects and is responsible to manage the tree nodes. It has methods like "add()", "remove()", "convertTo()", "enable()", etc.
  • Interfaces will be used to defined APIs to the tree node and the manager so that they can be extended to different type of packages.
The U.I.#
- TBD
- Action#
The action is invoke at the end of the wizard when user click "Finish", not from any context menu or toolbar icon
Checking out packages#
  • Depending on the selection in the U.I., the action does either a SVN "checkout" or "export"
  • In both scenarios, the action preserves the source tree layout as the same as it's posted on F27
  • For dependent packages, it prompts the user to check them out at the same time and gives "project may not build if select no" warning in the prompt
Creating projects#
  • Projects to be created are defined by searching for "module.tmpl" files in the packages.
  • Project references are defined by the project dependencies. When creating the projects references should be created as well
  • Should leverage the existing source import action. It currently does an import on the source zip file, will extend it to support source tree checkout
