wiki1804: Kernel_team_meeting_20080114
OS Status Meeting Minutes
January 14, 2008
Steve Bergwerff
  • Important Trinity 2 dates to be aware of:
    • M4 test review later today
    • M5 build is tomorrow
Brian Stecher
  • Provided first part of kernel talk for support team training.
  • Had been going through code inspections for locking done on Memory Partitioning. More left to do.
  • Resolved Trinity2 PR 54546. One of the test machines would only let you login as root.
  • Working on Trinity2 PR 54559 SMP mapping issue as top priority. All other activities are on hold.
Mike Kisel
  • Have been working on two Trinity 2 test stopper PRs that have been there for last 2 milestone builds but can't reproduce the issue. Working with build team to understand why this is the case.
  • Renamed APS utility to AP.
  • Have two outstanding code inspections out for review on Memory Partitioning.
  • Waiting on review from Brian and Attilla on potential locking issues with Memory Partiioning.
  • Working on PR 43611 for Memory Partitioning.
  • Generally working on solidifying Memory Partitioning for Trinity2 and seeing what can be put in for tomorrow's build.
Attilla Danko
  • Had a meeting on adaptive partitioning with a large customer.
  • Helping out on Memory Partitioning with code reviews and solutions for SMP mutual exclusion.
  • Working on Trinity 2 PR 52847 for issues with one of the ppc boards.
  • Responding to questions regarding process certifications.
  • Had a meeting on better integration of static analysis tools into the development infrastructure.
Colin Burgess
  • Fixed Trinity 2 PR 54563. Customer reported issue with devctl call on SMP.
  • Working on tiger team for getting a full head branch using the gcc 4.2.1 compiler.
  • Working on merge of Trinity2 branches needed for a customer to continue testing. Need to meet with customer ot understand some of their proposed changes.
  • Working on a optimization in Trinity2 that was initially implemented as a temporary workaround but now require a full solution.
  • Involved in compiler discussions with a customer on gcc 4.2.1.
Scott Miller
  • Focusing on analysis of Trinity2 benchmark results. Tried running the benchmarks on a laptop. Seeing only improvmements in the numbers. Will verify that the same compiler version is being used for the comparisons.
  • Looking at Trinity2 PR 54433 for a test stopper issue with pathname corruption.
  • Attended Brian's kernel training seesion.
Doug Bailey
  • Working on Trinity2 PR 53696 and PR 52939 to fix two test case failures. Difficult to reproduce.
  • Fixed PR 53959 and a PSP was created and tested.
  • Working on some experimental code for SH SMP
  • Planning to have Trinity2 PR 52925 fix in for this weeks milestone build.
Shiv Nagarajan
  • Working on three customer reported issues for Trinity 2.
    • PR 53749 for a select() issue with telnet. Seem to have discovered the problem Tested it and waiting on a code review.
    • PR 53750 for a reported crash triggered by a qnet test. Still unable to reproduce it.
    • PR 54903 for a reported crash crash seen under low memory conditions.
David Joo
  • Not in attendance today.
Peter Mitsis
  • Working on Tirnity 2 PR 54456 for a problem mounting a flash device. Problem appears to be a loop in a link list in procmgr.
Angelina Gomes
  • Was on vacation last week
  • Currently working on OS and IDE documentation.
  • Received email from Mike with additional details on AP utility.
