wiki1654: Networking_other_wiki_page (Version 16)
Networking Utilities, Libraries, etc.#
New Utilities#
The Networking project includes the following new or updated utilities and services:
  • sbin/
    • brconfig New bridge configuration utility
    • ifconfig Updated interface configure utility
    • ifwatchd New "interface watch" utility
    • pfctl New packet filter control utility
    • pppoectl Updated PPPoE control utility
    • route Updated route configuration utility
    • setkey Updated IPSec key manipulation utility
    • sysctl Updated stack configuration / control utility
  • usr/bin/
    • altqstat New traffic shaping ("ALTernate Queuing") statistics utility
    • arp Updated address resolution protocol utility
    • ftp Updated FTP client
    • netstat Updated netstat utility
    • ping Updated ping utilities for v4.
    • ping6 Updated ping utilities for v6.
    • sockstat New socket status utility
    • tbrconfig New Token Bucket Regulator configuration utility for an output queue
    • traceroute Updated route tracing utilities for v4.
    • traceroute6 Updated route tracing utilities for v6.
  • usr/sbin
    • dhcp.client Updated dhcp client (handles longer interface names)
    • ftpd Updated FTP daemon
    • hostapd New ~Wi-Fi Host Access Point Daemon
    • inetd Updated Internet Daemon
    • nicinfo Updated network interface card information utility
    • pppd Updated PPP daemon
    • pppoed Updated PPP over Ethernet Daemon
    • tcpdump New packet capture and display utility
    • wpa_cli New WPA command line utility
    • wpa_passphrase New WPA network block pre-shared key generation tool
    • wpa_supplicant New WPA / WPA2 supplicant
Libraries#
  • libcrypto OpenSSL cryptography library
  • libipsec Updated ipsec library from the ipsec-tools project
  • libssl OpenSSL library
  • libpcap Packet Capture library
  • libwlconfig ~Wi-Fi configuration library (in development)
Protocols#
Transparent Distributed Processing (aka QNET)#
Please see the QNET wiki page
Auto IP (or IPv4 Link Local Address as in RFC)#
"AutoIP" is an implementation of RFC 3927, "Dynamic Configuration of IPv4 Link-Local Addresses". The source lives in sys/lsm/autoip and is implemented as a shared object so it can be loaded into the stack dynamically.
The code is pretty straight forward. A filter function is hooked in which examines the in/out ARP packets. For incoming ARP packets, it checks to see if it is in conflict with the Link Local Address which we've selected, and it then defends or re-selects the address accordingly. For outgoing packets, an ARP REPLY packet broadcast is sent onto the network (instead of uni-cast).
"AutoIP" can be started same as other lsm modules:
* ~io-pkt -d <driver> -p autoip
The only thing to watch out for, is if you use autoip in a multi-interface environment (say you have 2 network card). Try to use the "if=" option to target the protocol to a specific interface. If you really want both of your interfaces to run in "autoip" mode, make sure you understand exactly what could happen. The RFC has a whole chapter of "Considerations for Multiple Interfaces" that discusses this (see section 3 of rfc3927).
