wiki1357: CoreOSSourceDescription
Neutrino OS Source Descriptions#
NOTE: This table is automatically generated. Any edits you make by hand will be lost.
Source ModuleSource Module Description
lib/asyncmsg Asynchronous Message Passing Library
lib/besselBessel math functions library
lib/cC runtime library
lib/compat Internal Utility Library
lib/elf Library for querying/manipulating ELF files
lib/kdutilInternal library for shared routines in kdebug/kdumper
lib/loginSupport library for login
lib/lzoLZO compression library
lib/mMath header files
lib/mallocDebugging malloc library
lib/mig4ntoProvides cover functions for many QNX 4 functions that are not available in QNX Neutrino.
lib/miscSupport library for tcpip utils. Misc functions
lib/mqPOSIX message queue library
lib/ncursesNcurses lib
lib/qnx43qnx43 library
lib/qnxterm qnxterm library
lib/shutdown Shutdown library, a library that implements core system shutdown functionality
lib/termcaptermcap
lib/traceparserLibrary for parsing tracelogger output
lib/uclUCL compression library.
lib/util Internal Utility Library
lib/zCompression/decompression library
services/cronClock server
services/devc-dittoCharacter device cloner
services/dumperProcess crash dump file creation daemon
services/initProcess control initialization
services/kdebugKernel Debugger
services/kdumperKernel Dumper
services/lpdPrinter services
services/mig4ntoQNX 4 to QNX Neutrino migration kit process manager.
services/mqPOSIX message queue daemon
services/mqueuePOSIX message queue and named semaphore daemon
services/pipePOSIX pipe daemon
services/random /dev/random Service
services/sloggerQNX system logging daemon
services/syslogdSystem Logger daemon
services/systemMicrokernel and process manager for $(CPU_TYPE) processors
services/tinitTerminal initialization
services/traceloggerTrace logger utility
utils/a/apAP: Adaptive Partitioning Utility
utils/a/asaasa
utils/b/basenameget the base filename from a path
utils/b/bcarbitrary precision arithmetic language
utils/b/bzip2bzip2 compression utility
utils/c/canonical_dos_pathcanonical_dos_path
utils/c/catprint a file to stdout
utils/c/cfgopenCheck for existance of configuration files
utils/c/chmodchange file permissions
utils/c/chownchange file ownership
utils/c/cksumcalculate checksum on file
utils/c/cmpcompare two files
utils/c/commcopare files
utils/c/confstrconfstr
utils/c/coreinfoDisplay information about a Neutrino core file
utils/c/cpcopy files
utils/c/crontabedit the cron schedules
utils/c/csplitcsplit
utils/c/cutcut out selected fields of each line of a file
utils/d/dateDisplay or set the date and time
utils/d/dddump data
utils/d/deflateNone
utils/d/diffdetermine differences between two files
utils/d/diff3Show differences among three files
utils/d/dirnameprint the directory portion of a path
utils/d/ditNone
utils/d/dudisplay disk usage
utils/e/echoprint text to stdout
utils/e/edNone
utils/e/elfdifftest that ELF binaries are functionally identical
utils/e/elvis/elvistext editor of the 'vi' persuasion
utils/e/enterkdinternal utility for getting into kernel debugger
utils/e/envprints out the current working environment
utils/e/errnoprint the text corresponding to an error number
utils/e/eshEmbedded shell
utils/e/expandConvert tabs to spaces
utils/e/exprEvaluate arguments as an expression
utils/f/falseReturn false value \(POSIX\)
utils/f/filedetermine the type of file
utils/f/findfind files
utils/f/fmtformats concatenated input
utils/f/foldfold lines in a file
utils/f/freezecompresses files
utils/f/fstatShow file\'s stat structure
utils/f/fullpathoutput fully qualified path
utils/f/fuserList processes with open files \(POSIX\)
utils/g/getconfget/set configuration information
utils/g/gettystandard unix getty - listens on tty for login
utils/g/grepsearch text for regular expressions
utils/h/hdDisplay files in decimal, hex, octal, or ASCII
utils/h/headprint first part of file
utils/h/hogsprint cpu utilization
utils/i/idreturn user id
utils/i/imagemanipUtility for processing files
utils/j/joinMerge sorted files
utils/k/kdserver"Kernel Dump Server (for use with GDB)"
utils/k/killTerminate or signal processes
utils/l/lddPrint shared libraries required by program
utils/l/lesspaginate files
utils/l/linkCreate a link to an existing file
utils/l/lnlink files
utils/l/ln-wsimulate ln under windows
utils/l/loggersystem logging utility
utils/l/loginLog in
utils/l/logoutTerminate a session
utils/l/lsList directory contents \(POSIX\)
utils/l/lxshow extents used by file
utils/m/mailxcheck mail
utils/m/mcsManage comment sections
utils/m/mesgEnable, disable, or query broadcast messages
utils/m/mig4ntoIdentifies areas in programs that need attention during the migration process.
utils/m/mkasmoffconvert elf or coff object files into assembler include files
utils/m/mkdirmake directory
utils/m/mkrecconvert imagefile for eeprom burning
utils/m/mkromMake BIOS extension signature and x86 cksum images
utils/m/mkxfsbuild embeddable filesystems
utils/m/modemNone
utils/m/mountMount a filesystem
utils/m/mvMove files
utils/n/newgrpChange to a new group
utils/n/nicelower priority of a process
utils/n/nohuprun program in background immune from hangups
utils/o/onExecute a command on another tty
utils/o/opgaping security hole
utils/p/passwdChange the login password or create new user names
utils/p/pastepaste utility
utils/p/pathchkCheck pathnames \(POSIX\)
utils/p/pax_qnxposix pax utility
utils/p/pidinDisplay system statistics
utils/p/prtext pagination and formatting utility
utils/p/printfformatted printing
utils/p/psReport process status
utils/p/pwdprint present working directory
utils/q/qcpsend and recieve information by serial communication
utils/q/qedQNX fullscreen Editor
utils/q/qkcpquick copy utility using DirectIO method
utils/q/qtalkTalk over a communications line
utils/r/reniceAdjust the priorities of running processes
utils/r/resource_seedUtility to seed system resources, such as DMA channels and IRQs, to the resource database manager
utils/r/rmRemove files
utils/r/rmdirRemove directories
utils/r/rtcSet or get date from realtime clock
utils/s/scriptscript
utils/s/seedresNone
utils/s/seed_hsrNone
utils/s/sendntoSend a boot image to an embedded device
utils/s/setconfSet a configuration string
utils/s/showmemDisplay detailed memory information about a Neutrino target
utils/s/shutdownNone
utils/s/slayKill or modify a process by name
utils/s/sleepSuspend execution for an interval
utils/s/sloginfo"Utility to display system log (slogger) messages"
utils/s/sortSort, merge, or sequence-check text files
utils/s/spatchfull screen patch utility
utils/s/splitsplit a text file into smaller files
utils/s/stringsextract strings from binary file
utils/s/sttySet tty attributes
utils/s/suSwitch user ID
utils/s/swapctlControl the swap device
utils/s/syncUpdate filesystems to match cached data
utils/s/sysctlGet or set socket manager operating parameters
utils/t/tailprint last lines of a file
utils/t/teeduplicate stdin
utils/t/termdeftermdef
utils/t/textmodeUsed to try to switch back to text mode using Video BIOS and unlock the console
utils/t/texttoconvert dos/unix/qnx text files
utils/t/timeDetermine the execution time of a command
utils/t/topprint system usage
utils/t/touchChange file access and modification times
utils/t/trTranslate characters
utils/t/traceprinterUtility to display tracelogger output
utils/t/trueReturn true value
utils/t/ttyReturn users terminal name
utils/u/umaskumask
utils/u/umountUnmount a device
utils/u/unameReturn system name
utils/u/unexpandconvert spaces to tabs
utils/u/unifdefremove C/C++ ifdefs
utils/u/uniqremove duplicates
utils/u/unlinkDelete a file
utils/u/useprint use message
utils/u/usemsgget or set use messages
utils/u/uuduud
utils/u/uueuue
utils/w/wcCount words, lines, and bytes
utils/w/whichLocate a program file
utils/w/whoShow list of logged on users
utils/x/xargsConstruct argument list\(s\) and invoke a program
