| wiki1351: Cached_Confstr (Version 1) |
Cached confstr() values#The confstr() function fetches system configuration strings, such as CS_TIMEZONE. In Trinity 2, there is a new option to cache these values locally, making use of the procmgr_event_notify() API to be notified of any change to a configuration string. You can enable default handling of confstr caching by calling confstr_cache_attach(). NOTE - each application can only have one procmgr_event_notify() event registered (although that event may be triggered by multiple flags). If you are already using procmgr_event_notify() elsewhere in your application, and wish to make use of confstr caching, simply add PROCMGR_EVENT_CONFSTR to your set of notification flags, and enable confstr caching by calling confstr_cache_enable(). Upon receipt of the registered event, invalidate the cache with confstr_cache_invalidate(). You can also disable caching by calling confstr_cache_disable(). |
