wiki1347: Downloads_gcc4.2Preview (Version 10)
GCC 4.2 Preview Build#
Download the latest stable build of the QNX port for GCC 4.2, and experiment with its new features. Please provide your feedback using the Core Development Tools Forum.
What's new?#
GCC 4.2.1 port#
  • New C parser (available in gcc 4.1 and newer). Yacc-based C parser was replaced with a faster hand-written parser.
  • New C++ parser (availble in gcc 3.4 and newer). g++ is now much closer to full conformance to the ISO/ANSI C++ standard.
  • New optimization framework based on SSA. New code transformations include dead store elimination, constant propagation, value range propagation, load and store motion, strength reduction and many more.
  • Optimized ARM floating point emulation routines.
  • Support for precompiled headers (requires updated qcc).
Binutils 2.17 port#
  • Support added for ARM V6.
  • Support added for ARM VFP floating-point instruction set.
  • Support added for SH4a and variants.
  • Support added for SSE3 instructions.
Installation Instructions#
To install the GCC 4.2 preview:
  1. If you haven't done so yet, download and install QNX Momentics 6.3.2. A 90-day evaluation version and perpetual non-commercial licenses are available here.
  2. Download GCC 4.2 from the Project Download area. If you have a Windows host, download win32-gcc-4.2.1.zip. If you have a Linux host, download linux-gcc-4.2.1.tar.gz. If you have a Neutrino host, download the nto-gcc-4.2.1.tar.gz.
  3. Download Binutis 2.17 from the Project Download area. If you have a Windows host, download win32-binutils-2.17.zip. If you have a Linux host, download linux-binutils-2.17.tar.gz. If you have a Neutrino host, download the nto-binutils-2.17.tar.gz.
  4. Once you have the two packages, change directories to your root QNX632 directory. For example, on a Windows host, the default is typically C:\QNX632, however your install may differ. For Linux and Neutrino hosts, the default root QNX directories are usually /opt/qnx632 and /usr/qnx632, respectively.
  5. Uncompress the GCC 4.2 and Binutils 2.17 packages into this directory. If you are on a system that has write permissions to $QNX_HOST and $QNX_TARGET, switch to superuser/administrator access before uncompressing.
After You Install#
After the packages are uncompressed, you will be able to use the GCC 4.2 compiler by invoking the qcc driver and specifying the 4.2.1 version. For example: qcc -V4.2.1,gcc_ntoshle helloworld.c. GCC 4.2.1 will also be listed as an available compiler within the IDE.
Licensing#
This is experimental code being provided for evaluation purposes only, and is under the terms of a valid QNX Momentics development tool license agreement.
