| wiki1246: AnatomyOfTheCLibrary (Version 3) |
Anatomy of the C Library#After the kernel/process manager the C library is the heart and soul of Neutrino applications. Where is it?#The C library (henceforce known as libc) lives with all of the common libraries in /lib/c part of the tree. What is in it?#The browsing the content of libc is like going to a great buffet. It has content ranging the from the client stubs for the Neutrino kernel calls to the intricate server bindings for resource managers to the mundane code for min() (yes, there really is a function). Something for everyone! Major sections of libc include:
How is it organized?#The top level of the libc contains directories that allow some "intuitive" navigation and classification.
The other few token directories not listed contain the header files (public ones in "public" and libc private ones in "inc") as well as the main build directory for the library "lib". What is interesting about this is the build process for libc. In order to maintain a relatively "svelt" figure for the general C library, we have specifically relegated certain functionalities to the static version of the library. High runner functionality is maintained in the shared version of the library while discreet functions often found only in one or two applications (like login()) are shifted off to the static library. You can see the full configuration if you take a peek at the contents of the lib/c/lib/common.mk file. What can I do with it?#Without a doubt, trolling the source is cool and exciting, but you want more! Probably the most refreshing thing that you can now do is to take advantage of the source being available to help debug those issues where you really wanted to get into libc to find out what was going on. If this is the case, then the easiest thing to is to bring the libc source into your application!
Fast and Easy! Of course if you really want to go all the way, then you should really build a custom libc shared object with full debug information (so.g variants in the tree) and join the ranks of true developers who will attach a debugger to just about anything and get into its guts. Hey ... who knows, maybe doing this will mean you stop passing NULL into printf() and calling up to us and tell us that we are breaking your application 'cause the stack trace tells you so! |
