| wiki1134: APS_source |
Adpaptive Partitioning Scheduler: Navigating the Source #What is it#See the Apaptive Partioning Scheduler wiki.Where is the source?#Browse the source in /ker/aps/. Also any checkout of the whole kernel, done affter 2008-02-29, will include the aps source. Other things you may need to know:
What is the file structure of /services/system/ker/aps#
aps_alg.c, .h
algorithm for which partition to schedule a thread from
aps_application_error.c
once function for forcing reboots when a partition goes bankrupt.
(just so the crash message will say "application error" rather than "nano_aps.c")
aps_config.c
implements the api functions in ker_aps.c to configure the scheduler
aps_crit.c, .h
handling of critical time and partition bankruptcy
aps_data.c, .h
definitions, and init routines, for partition data structures, including the scheduling window
also contains the function to create the first partition, System.
aps_time.c
function to time execution of threads: microbill
hook into clock interrupt handler for rotating the scheduling and reporting windows
aps_trace.c
tracelogger functions
init_aps.S
linkage to make the aps scheduler into kernel module: libmod_aps.a
ker_aps.c
implements the SchedCtl function for the aps subcommands. Contains parameter checking,
security checking. Invokes functions in aps_config.c once it locks the kernel
nano_aps.c
analog of ker/nano_sched.c. Implementation of scheduling primitives ready(), block_and_ready(),
mark_running() and reched()
Also contains code to initialize aps.
proto_aps.h
function prototypes for all of aps.
