wiki1095: Resources_nasm (Version 6)
NASM Resources#
NASM, is a free Intel x86 assembler that allows assembly applications to be ported across 32-bit x86 OSes.
User Resources#
Developer Resources#
How to build#
  1. Check out source from branch.
  2. Change directory into a build directory that matches the desired configuration. If you want the NASM executable to run on a Linux host, change into the linux-x86-o/ directory. If you desire a Windows hosted nasm executable, change into win32-x86-o/.
  3. Remove any existing files with the exception of 'GNUmakefile'.
  4. Type 'make'. The build will take sometime to complete.
  5. Once Make has successfully completed, if you are on a system that has write permissions on $QNX_HOST and $QNX_TARGET, switch to superuser/administrator access.
  6. Copy the NASM executable into $QNX_HOST/usr/bin/.
Branches#
BranchVersionStatus
tools/nasm/trun/k 0.98.39 Active
tools/nasm/branches/nasm_0_98_35_branch/ 0.98.35 Inactive
