Forum Topic - Lockup problem with Net.e1000 Net.r6040:
HI there
I am currently attempting to evaluate QNX 4.25 on a Vortex DX3.  The SBC has two ethernet interfaces.  As such I am
having issues with both of them.
First point to note I am only ever running one driver at any given time.
Net.e1000
I bring it all up happily and then begin my test by ftping a file then uploading it again.  When it runs at 100 MBps/
Full Duplex after about 60 to 100 operations the driver stops responding even to ping.
I cannot ping out of the board either.
I run trace log and get (55) NET raw app could not buffer pkt.
Netinfo shows no errors of any kind and neither does netstat.
The only way to bring it back up and working is to slay and relaunch everything including Net.
I have verbose mode turned on for each and the driver -vvv
Neither prints anything to console upon the error.
I have already switched cables and removed the switch etc.
Net.r6040
This one is slightly more problematic.   Doing the same test as above with ping also running I suffer a lot of timeouts
on ping.  I then run out test application which just echoe UDP packets back to a client.  And it times out as well.
I have tried the released driver and a patched one from these forums in the 6040 post.
Get the same issues on both.
The r6040 is the onboard SOC one for the Vortex and the i210 is on the southbridge connected to it.
Hoping someone may have insight
Thanks in advance
Paul
Re: Lockup problem with Net.e1000 Net.r6040
Please can you post the output from "sin ver" on your system while running the e1000 driver?
Thanks, Hugh.
On 2019-02-04, 11:04 AM, "Paul Graham" <community-noreply@qnx.com> wrote:
    HI there
    Net.e1000
/Full Duplex after about 60 to 100 operations the driver stops responding even to ping.
    Net.r6040
timeouts on ping.  I then run out test application which just echoe UDP packets back to a client.  And it times out as
well.
    Thanks in advance
    Paul
    General
    http://community.qnx.com/sf/go/post119468
    To cancel your subscription to this discussion, please e-mail general-qnx4-unsubscribe@community.qnx.com
See below.  I am aware there is the newer driver in 2015 but I get the same issue with it also which is why i downgraded
 by 1 version to the one listed below.
I ran test overnight with it running at 10 Mpbs FDX and did not encounter an issue after 2000 tests.  But at 100 Mpbs
FDX it fails generally within 100 even with a bigger slug between each iteration of test (from 1 to 10 seconds as it is
now)
Everything else like Net I think is up to date.
PROGRAM                 NAME         VERSION DATE
sys/Proc32              Proc         4.25Q   Jul 18 2005
sys/Slib32              Slib32       4.24B   Aug 12 1997
/bin/Fsys               Fsys32       4.24Z   Jul 06 2009
/bin/Fsys.atapi         atapi        4.25G   Jun 10 2010
//1/bin/Dev32           Dev32        4.23G   Oct 04 1996
//1/bin/Pipe            Pipe         4.23A   Feb 26 1996
//1/bin/Dev32.ansi      Dev32.ansi   4.23H   Nov 21 1996
//1/bin/Dev32.ser       Dev.ser      4.25A   Feb 14 2003
//1/bin/Net             Net          4.25G   Jul 06 2010
//1/bin/Net.e1000       Net.e1000    4.25D   Dec 19 2013
//1/usr/ucb/Socket      Socket       4.25K   Feb 12 2003
I doubt very much that this is a driver problem, as the e1000 driver has been running at many sites for years. This
rather sounds like a board/driver combination problem.
I have been running tests on the Net.e1000 4.25E for several hours at 100Mb/s without any problems. There isn't much we
can do without hardware.
downgraded by 1 version to the one listed below.
Mpbs FDX it fails generally within 100 even with a bigger slug between each iteration of test (from 1 to 10 seconds as
it is now)
    General
    http://community.qnx.com/sf/go/post119472
I have switched to another board and it runs better for still has the same issue eventually
The board is a Adlink CM1-86DX3.  It has two interfaces one i210 and one R6040 (Vortex SoC).  They both share the same
IRQ line.
I dont know if this would factor into their being an issue,  Just done a test with both drivers running and e1000
configured with address.  Still fails.
In your setups are you launching the Net.e1000 with any particular settings
I'm just running "Net.e1000 -l2 -d1533" as it is the second interface on my machine. Can you send me the steps you run
to reproduce the problem?
If the i210 and Vortex are sharing the same interrupt, are any other device using the same interrupt?
same IRQ line.
    General
    http://community.qnx.com/sf/go/post119475
Yeah sure
So my system comes up with no network configured.  Everything is down.
I then manually run
Net &
Net.e1000 -l1 &
nameloc &
Socket localhost &
ifconfig lo0 localhost up
ifconfig en1 144.179.1.199 netmask 255.255.255.0 up
inetd
I wait a few seconds between each step.  Speed of PC and board us 100 Mpbs FDX.  No switches in the way.
Also for the last two iterations I have been running the second driver also Net.r6040 -l2 & launched after Net.e1000
I then start a script running on PC which connects to FTP, does a 3 meg download, then uploads the same file and then
disconnects.  Waits 1 second then repeats.
Eventually it just stops responding to FTP and only way to recover it is to slay everything including Net and relaunch
as above.
When I ping from PC to card I can see from netinfo that packets are being recieved but the pings fail and board
transmits nothing.
Please can you post your script as well?
On 2019-02-05, 9:16 AM, "Paul Graham" <community-noreply@qnx.com> wrote:
    Yeah sure
    I then manually run
    Net &
    Net.e1000 -l1 &
    nameloc &
    Socket localhost &
    inetd
then disconnects.  Waits 1 second then repeats.
relaunch as above.
transmits nothing.
    General
    http://community.qnx.com/sf/go/post119477
Python 2.7
Downloads a 3 meg text file
Attachment: Text ftp.py 3.53 KB
Are you sure that this isn't a memory problem? If you run "sin in" intermittently on another console while you are
running your ftp test, does the memory available stay the same or does it decrease?
On 2019-02-05, 9:29 AM, "Paul Graham" <community-noreply@qnx.com> wrote:
    Python 2.7
    General
    http://community.qnx.com/sf/go/post119479
The Memory in the top section remains at about 1615/2031 M virtual sits at about  1219/2088 M
But I am running test again with switch back in and PC forced to 10 Mpbs and board running at 100.
Heapl 22928
Both it and virtual are fluctuating slightly at present but not by much.
So far it has passed the previous success limit of 444.
I will repeat the test on the faster speed again and run sin in.  But I have run it before and not noticed anything
untoward?
Anything particular I should  look out for?
I am away to make a simple TCP server and client to run full packets at the board and echo them to test the interface
more in line with the kind of tarf
Hmm nope
I have python 2.7.15 installed on windows 7.  And do not set anything else except tick box in installer to run add to
system PATH so I can run from command prompt.
Then from command line run: python ftp.py
Python fails immediately if it cannot do something as its runtime interpreted.
The memory stays consistent.
We have over 2 Gig of Ram on board.  And still have 1600 Meg available.
Virtual memory is at 1225/2000 odd Meg
HeapL is 22798
Nothing changes much.
I have run your script from my Ubuntu Linux PC to my QNX4 PC at 1Gb/s for 100 loops without any problems. The file size
is 195MB.
I am now running the same test via a 100Mb/s switch to see if anything changes.
    HeapL is 22798
    General
    http://community.qnx.com/sf/go/post119485
Attached,
Python 2.7
Using standard python libs.
Downloads a meg meg text file
Attachment: Text ftp.py 3.53 KB Text udplog2.txt 2.96 MB
I'm not familiar with python, but do you set any environment variables? I get an "ImportError: No module name os".
On 2019-02-05, 9:32 AM, "Paul Graham" <community-noreply@qnx.com> wrote:
    Attached,
    Python 2.7
    General
    http://community.qnx.com/sf/go/post119480
Latest status.
Ran with new board and it gets to 400 before locking up.
Setting PC to 10 Mbps FDX through switch with board set to 100 Mbps FDX.  Test appears to run without issue.  Have run
sin proxies and sin timers and there does not appear to be a build up of either.
I left your test running last night, and this morning it is still running with 1300 loops completed. This is running
through a 100Mb/s switch.
On 2019-02-06, 4:19 AM, "Paul Graham" <community-noreply@qnx.com> wrote:
    Latest status.
run sin proxies and sin timers and there does not appear to be a build up of either.
    General
    http://community.qnx.com/sf/go/post119487
Yeah I left a test running while off with PC at 10 Mbps FDX through a 100 Mbpos switch with board runnig at 100 Mbps FDX
It got to 27900 completions before it locked up
>  1300 loops completed. This is running through a 100Mb/s switch.
>     Latest status.
> Test appears to run without issue.  Have run sin proxies and sin timers and
>     _______________________________________________
>     General
At this point I think that your best bet would be to contact your QNX sales representative and make arrangements to send
 us your hardware, as we are unable to reproduce this problem with the hardware that we have.
Thanks, Hugh.
 FDX.
    >     Latest status.
    >     General
    General
    http://community.qnx.com/sf/go/post119522
Can you post the output from "sin" and "sin irq" when the lockup occurs?
    Latest status.
    General
Yeah will do.  I'll be back at it today so will recreate the failure and get that info
Hi
Sorry for the delay.
Here is a screen shot of the sin irq stuff.  Doesn't mean much to me I am afraid
Attachment: Image 20190215_113024.jpg 4.15 MB
