Forum Topic - Dev32.ser - System freezes (shared IRQs issue?):
Hi all,
In an embedded system (running QNX 4.25), I replaced the old Kontron CPU by an ADLINK cPCI-3615D. This systems needs
several external  multi-serial boards on the cPCI bus (3x 8 ports - Tenta SCOM-0801).
I'm now facing problems when I launch the Dev32.ser driver for the tenta boards. I noticed that it crashes if the IRQ is
 already used, but maybe It's just a coincidence...
My previous CPU was allocating the IRQs on the full available range (1 to 15). With this CPU I was able to set up 24
serial ports using Dev32.ser, by blocks of 4 or 8, sometimes sharing IRQs with /Net without problem.
The new Adlink  assigns  only a few  IRQ, and  shared. I have found a slot configuration using a single tenta board
(with other I/O boards) where the tenta board have an IRQ for its own ant it works correctly. If I add an other serial
card which shares an IRQ with /Net or pg.i830, system hangs when launching Dev32.ser for this board.
Does anyone have an opinion on this issue?
Thanks a lot for your help.
Patrick
Re: Dev32.ser - System freezes (shared IRQs issue?)
Hi Patrick,
Tell us more technical details about the issue. Which QNX 4 version do you use? What is Dev32.ser version? Also attach
output of following commands:
show_pci -vvv
sin arg
sin ver
sin irq
How do you launch Dev32.ser driver? Can you reproduce the issue without launching network or/and graphics drivers?
2 сент. 2015 г., в 18:37:01, Patrick JAUSSAUD <community-noreply@qnx.com> написал:
> Hi all,
is already used, but maybe It's just a coincidence...
> Patrick
> http://community.qnx.com/sf/go/post114402
Hi Oleg,
You'll find attached the results of the commands you asked and also the commands I launch for the Dev32.ser driver.
As you told me, I tried to disable the network an graphics driver at startup.
In this situation sin irq gives something like:
 RQ   PID  PROGRAM                    CS:IP      DS
 -1    18     //1/bin/Dev32            0005:005760 000D
 -1    31     //1/bin/Dev32.ansi     0005:005DC0 000D
  0    1       /boot/sys/Proc32       00F0:004D83 00F8
  1    31     //1/bin/Dev32.ansi     0005:00690C 000D
  6    5       /bin/Fsys.atapi          0005:00B03E 000D
  13  1       /boot/sys/Proc32       00F0:004D47 00F8
Show_pci tells me that my tenta cards use IRQ 4, 5 and 6.
If I launch the Dev32.ser driver for the ones with IRQ 4 and 5, its OK.
Then, if I start the pg.i830 (IRQ4) driver, system hangs.
When I launch the Dev32.ser driver for the board with IRQ 6, it freezes too (Fsys.atapi = IRQ6).
Concerning the Ethernet driver (Net.e1000) using IRQ 5:
If I start the Dev32.ser with IRQ 5 and after, I start the Net.e1000 (with IRQ 5 too), its seems to work correctly.
If I do the reverse operation, Net.e1000 first and then Dev32.ser, system hangs...
Thanks for your help
Patrick
Attachment: Text Dev32.ser_setup.txt 349 bytes Text show_pci.txt 39.43 KB Text sin_arg.txt 1.17 KB Text sin_irqs.txt 809 bytes Text sin_ver.txt 1.13 KB
Hi Patrick,
How did you decide which ports and irqs specify to serial driver? Why do you use ports from 1601h:a801h device? I didn’
t find quite detailed specification for Tenta SCOM-0801, but I guess it’s incorrect to specify PCI bridge I/O ports to
Dev32.ser driver.
I guess that according to your show_pci output you should use following port,irq pairs for first board:
b800,4 b808,4 b810,4 b818,4 b880,4 b888,4 b890,4 b898,4
for second board:
c080,5 c088,5 c090,5 c098,5 c400,5 c408,5 c410,5 c418,5
for third board:
c880,6 c888,6 c890,6 c898,6 cc00,6 cc08,6 cc10,6 cc18,6
Can you test my suggestion?
3 сент. 2015 г., в 17:47:36, Patrick JAUSSAUD <community-noreply@qnx.com> написал:
> Hi Oleg,
> Patrick
> http://community.qnx.com/sf/go/post114407
> <sin_ver.txt><sin_arg.txt><sin_irqs.txt><show_pci.txt><Dev32.ser_setup.txt>
Hi Oleg,
To decide which ports and IRQs to specify to serial driver, I have an utility software that detects tenta boards and
generates the correct syntax for the driver (I don't have the source code of this exe).
Anyway, I tested what you propose and the result is the same. Even if I just launch the driver on the first 4 ports with
 1601h:a800h, it freezes if the IRQ is used by something else.
Actually, the tenta board has two OX16PCI954 quad UARTS (see datasheet attached). The first is associated with the PCI
bridge (1601:a801h I guess).
I tested again with my old CPU and it confirms that this way of allocating the base addresses and IRQs works correctly.
I attach  the results of the show-pci and sin commands on the old CPU.
Kind regards.
Patrick
Attachment: PDF ox16pci954ds.pdf 656.55 KB Text show_pci_old_cpu.txt 34.67 KB Text sin_arg_old_cpu.txt 1.98 KB Text sin_irq_old_cpu.txt 1.42 KB Text sin_ver_old_cpu.txt 1.47 KB PDF tentaSCOM-080Xman.pdf 140.73 KB Text tenta_setup.txt 422 bytes
Hi Patrick,
Try the attached Dev.ser driver. This version should works better in case of shared IRQs.
$ cksum Dev.ser_20150922.tar
3900819030 31744 Dev.ser_20150922.tar
17 сент. 2015 г., в 15:54:29, Patrick JAUSSAUD <community-noreply@qnx.com> написал:
> Hi Oleg,
with 1601h:a800h, it freezes if the IRQ is used by something else.
. I attach  the results of the show-pci and sin commands on the old CPU.
> Kind regards.
> Patrick
> http://community.qnx.com/sf/go/post114458
> <sin_ver_old_cpu.txt><ox16pci954ds.pdf><tentaSCOM-080Xman.pdf><sin_arg_old_cpu.txt><sin_irq_old_cpu.txt><
show_pci_old_cpu.txt><tenta_setup.txt>
Attachment: Compressed file Dev.ser_20150922.tar 31 KB
Hi Oleg,
I've tried the Dev.ser you sent and it seems to work correctly now.
Thanks a lot!
Are there any differences with the "official" Dev32.ser?
Kind regards.
Patrick
Hi Patrick,
This is more recent version that improves work with shared interrupts + small updates.
25 сент. 2015 г., в 17:00:28, Patrick JAUSSAUD <community-noreply@qnx.com> написал:
> Hi Oleg,
> Thanks a lot!
> Kind regards.
> Patrick
> http://community.qnx.com/sf/go/post114525
