Re: RTL8111B does not get 1000BT - 4.25
07/06/2010 11:32 AM
post58717
I have updated the netinfo utility and re-run the commands. I also grabbed and updated the Net utility you released a
few days ago. I have started the driver with and without args. When set to auto, the link says it is established at
1000BT, but does not transmit or receive packets. If I simply move to a 100BT connection, it works fine. Link state
changes show on the console, so I can move between networks and it will auto-negotiate the proper rate, but will only
pass data if on 100BT or less. Booted up on Ubuntu 10.4 and the GB network is fine on both 100BT and 1000BT networks.
