01/14/2010 8:20 AM
post45227
Hello Larry,
I think that problem isn't in the driver. There are several more probable
effects.
1. Problem in hardware. Can you test your software on another HW? What is
your result?
2. Highly loaded system. How many process in your system? I need output of
(with both Pg.flatdc and Pg.i830 drivers):
# sin ar
# sin ver
# sin ti
# sin ir
# sin in
# show_pci -vvv
3. Error in software. For instance, widget which implement of a mimic of a
plant may be not optimal.
> Hello Oleg,
> We are using 16 bpp. The Base Window has a widget to display date and
> time and a heartbeat indicator as well as a context specific title.
> The Main window consists of a mimic of a plant with various devices
> that get updated every 500 msec. The navigation window consists of
> three buttons for navigating back to the main and secondary
> directories and to the previous screen.
> When the user presses a button the main window gets replaced with a new
> one. When this window is being replaced we can see the background
> behind the window from the desktop. We can make this more noticable
> by, for instance, placing a large yellow msgpad application behind.
> I hope this explanation helps. I look forward to your advice and
> suggestions.
> Thank you.
> Larry
> P.S. One noticable improvement is with the hardware cursor. If we
> place the cursor over a widget that is being regularly updated it no
> longer flickers. With the Pg.flatdc driver the flicker was very
> noticable.
> P.P.S Another piece of information that I just received is that this is
> the first time that they (we) are using multiple windows. Previously
> the application used a single full screen window that was replaced
> (re-drawn) as required. Now we have three windows, two of which
> overlap (the main and the navigation window).
> http://community.qnx.com/sf/go/post45062
