Forum Topic - tx_down() returned -1, errno 255: (10 Items)
A system of ours has this qnet log all over the place.  I understand errno 255 is no buffer space but more info would
help point me in the right direction.
This is with 6.3.2 e1000 driver running at 1Gig, tx description has been raised to 512.
RE: tx_down() returned -1, errno 255
Usually, the transmitting engine is halted for some reason, packets get
stuck in TX descript ring, once the ring is full, try to transmit will
result to a ENOBUF error.
-xtang
> From: Mario Charest [mailto:community-noreply@qnx.com]
> Sent: June 17, 2009 4:31 PM
> To: technology-networking
> Subject: tx_down() returned -1, errno 255
errno
> 255 is no buffer space but more info would help point me in the right
> direction.
been
> raised to 512.
> Technology
> http://community.qnx.com/sf/go/post32002
> From: Xiaodan Tang [mailto:community-noreply@qnx.com]
> Sent: June-17-09 4:35 PM
> Subject: RE: tx_down() returned -1, errno 255
Given the tx descriptor has been raised to 512 it`s unlikely if not impossible that the software fills the buffer, the
protocol (qnet) would have throttle it down right?  That would indicate the interrupt aren`t being received/generate?
What is odd is that we have tried two model of cards,  Intel 100Mbits with the speedo driver and Intel 1Gig with e1000
driver with the same error.
> -xtang
> errno
> > direction.
> been
> > raised to 512.
> > Technology
> Technology
> http://community.qnx.com/sf/go/post32003
> fills the buffer
Not so.  I have seen a single IP transmit request come
down from the stack with 100 fragments (!).  Generally
most drivers will try to defrag such a silly request,
but ...
Also, qnet will NOT pass down fragmented transmits
but it may pass down an awful lot of them, depending
upon what it is asked to do by the various clients
and servers.  IIRC procnto, when it is loading remote
executables, likes to read huge chunks.
I would try 4096 transmit descriptors to see if that
makes a difference.  I actually made that the default
on the now-deprecated devnp-i82544.so    :-)
aboyd    www.pittspecials.com/images/gat_t7.jpg
> From: Andrew Boyd [mailto:community-noreply@qnx.com]
> Sent: June-17-09 4:52 PM
> > fills the buffer
> but ...
Setting number of transmit descriptor to 4096 solved the problem, thank you
> Technology
> http://community.qnx.com/sf/go/post32007
Excellent.  We should probably create a PR to increase the default number
of transmit descriptors for both devn-e1000.so and devnp-e1000.so to at
least 1024.
I would personally prefer at least 2048 or even 4096, because it oesn't cost
hardly any memory, unlike rx descriptors.
aboyd
> Sent: June-18-09 4:44 PM
> thank you
> number
> least 1024.
Maybe also document what the error is about and how to fix it.  We had the same problem with the speedo driver.  As a
matter of fact wouldn`t a slower link speed results in more of these errors?
> cost
> aboyd
> Technology
> http://community.qnx.com/sf/go/post32073
Could it be PR68125? The netperf udp streaming shows many tx with
errors, E.g. nicinfo told "Memory Allocation Failures on Transmit .....
9008".
Weijie
Sent: June 18, 2009 4:44 PM
thank you
number
least 1024.
cost
aboyd
Technology
btw, another cause of the tx descriptor ring filling
up is that the remote end sent a pause frame, and asserted
flow control.
Generally, flow control should be enabled by the IEEE-standard
PHY auto-negotiation, if both ends support it, which is the
norm these days.
IIRC "ifconfig -v" will even tell you if flow control has
been enabled by PHY auto-negotiation (right of "media")
which is information which was never actually even output
by the nicinfo utility.
aboyd
Unfortunately it's 6.3.2
> Sent: June-17-09 4:59 PM
> flow control.
> norm these days.
> aboyd
> Technology
> http://community.qnx.com/sf/go/post32008
