Forum Topic - pppstats information in qnx 6.4 : (6 Items)
Hi
we are using ppc target having limited QNX file system
I was earlier using 6.3.2 kernel and for getting statastics of PPP link we use to use  cat /dev/socket/pppmgr ..
Now these commands are no more working and more over i had seen pppstats gives this information. But when i am trying
that i says cannot execute no such file or directory. I want to know what binary i need to add to my build other than
pppd i need to add to get pppstats running.
Do i need to do any changes in build file ?
2nd part : In help documents it says /etc/ppp folders contains info about ppp link, but i am using host QNX and i
connected ppp link between my target and host, but i am not able to see any such folder exisitng in host machine. what
do i need to do ?
Ravi
Re: pppstats information in qnx 6.4
On Fri, Feb 06, 2009 at 05:43:28AM -0500, ravi varma wrote:
> Hi
do i need to do ?
What stats in particular are you looking for?
We are looking to know the link statistics like :
No.of frames/bytes tranmistted /Received Etc over ppp link
-Ravi
> > Hi
> gives this information. But when i am trying that i says cannot execute no
> other than pppd i need to add to get pppstats running.
> ppp link, but i am using host QNX and i connected ppp link between my target
> what do i need to do ?
> -seanb
You can get number of bytes from 'netstat -inv'.  You can
get bytes, frames and a lot of other info from the
SIOCGIFDATA ioctl which populates a struct ifdatareq.
> -seanb
Hi
I tried the way you suggested, first of all thank you as i got introduced to different structures over the process.
code i am using is, every time ioctl call is failing i tried "/dev/ser2" assuming that my ppp0 interface runs on ser2, i
 am not getting what i should attach as file i.e /dev/PPP0 or /dev/(process id of ppp0) etc... the error code suggests "
Inappropriate I/O control operation", so let me know wher ei am going wrong.
struct ifdata
         char ifdr_name[IFNAMSIZ];
         struct if_data ifdr_data;
}ifdatareq;
int main()
	struct ifdatareq ifdr;
	struct if_data *ifi;
	unsigned char ifi_type;
	int fd;
   fd = open("/dev/ser2", O_RDWR | O_NOCTTY | O_NDELAY);
   while(1)
        if (ioctl(fd, SIOCGIFDATA, &ifdr) == -1)
	perror("Socket Bind failed\n");
	printf( "That means(%d): %s\n",errno, strerror(errno) );
	return -1;
       ifi = &ifdr.ifdr_data;
       ifi_type = ifi->ifi_type;
       printf("%c is number\n",ifi_type);
Thnaks
RAVI
> > -seanb
> Hi
 i am not getting what i should attach as file i.e /dev/PPP0 or /dev/(process id of ppp0) etc... the error code suggests
 "Inappropriate I/O control operation", so let me know wher ei am going wrong.
> struct ifdata
> }ifdatareq;
> int main()
> 	int fd;
/* A socket is needed here */
fd = socket(AF_INET, SOCK_DGRAM, 0);
>    while(1)
memset(&ifdr, 0x00, sizeof(ifdr));
strlcpy(ifdr.ifdr_name, "ppp0", sizeof(ifdr.ifdr_name));
/* where "ppp0" above is as reported by (for example), the ifconfig utility */
> 	return -1;
> Thnaks
> RAVI
> io-net migration
> http://community.qnx.com/sf/go/post21763
