Forum Topic - problem with asix usb-ethernet:
Hi
I have installed QNX in a Beagle board. I have a usb-ethernet dongle (Linksys ASIX AX88772 USB2.0 to Fast Ethernet
Adapter). However, I could not make it work.
When I run io-pkt-v4 -dasix, I see it's running via pidin.
   69646   1 roc/boot/io-pkt-v4  21r SIGWAITINFO
   69646   2 roc/boot/io-pkt-v4  21r RECEIVE     1
   69646   3 roc/boot/io-pkt-v4  21r REPLY       12295
when I run usb, it does not show asix:
# usb
USB 0 (EHCI) v1.10, v1.01 DDK, v1.01 HCD
USB 1 (MENTOR) v1.10, v1.01 DDK, v1.01 HCD
ifconfig gives me:
When I tried to add an ip address to en0, i get
# ifconfig en0 192.168.1.130
ifconfig: SIOCGIFFLAGS en0: No such device or address
Can someone help me out?
--Ahsan
Re: problem with asix usb-ethernet
Try looking at 'sloginfo' for more clues. And 'pidin mem' will tell you
if the driver is succesfully loaded in io-pkt or not.
/P
first "usb" should show the asix usb, if no then io-pkt won't drive it.
