Forum Topic - Verifying for a hardware loopback connection: (6 Items)
I had a requirement in which I need to verify for a hardware loopback connection running in QNX on a Target Board. In
order to test for the loopback connection I need to ping via one interface (assume en0) to other interface ( assume wm0
) and vice versa. The ping should only respond if the two interfaces are physically connected, and shouldn't respond
when not connected physically.
I am not able to find any suitable method to implement this, as QNX doesnt have support for ping via interface as in
Linux using '-I' as selected interface neither it has support for IP Tables in my knowledge.
Any guidance to implement hardware loopback connection will be of great help.
Prashant.
Re: Verifying for a hardware loopback connection
If your interfaces are on the same layer 3 network then this won't work
since all packets will always leave from only one interface because of
how the routing table works. To work around this you would either need
make sure the interfaces are on different layer 3 networks and setup
static routes for each OR you will need to run two instances of io-pkt,
one for each interface then you can have both interfaces on the same
layer 3 - you will also need to give set io-pkt option "-ptcpip
prefix=/altX" (where X is the instance number) for each instance so that
applications can target a specific instance:
SOCK=/alt1 ping <destination address2>
SOCK=/alt2 ping <destination address1>
See the online documentation for io-pkt for details.
On 14-06-18 06:14 AM, Prashant Singh Parihar wrote:
> Thanks,
> Prashant.
> http://community.qnx.com/sf/go/post110740
> To cancel your subscription to this discussion, please e-mail general-networking-unsubscribe@community.qnx.com
Does it have to be a ping? Using BPF it's possible to send a particular packet and also receive packets. It would be
quite simple to build a ping-like application.
Thanks for replying!
I tried to implement Packet Filtering before this posting this problem in Forum, but as it is a Target Board, with very
limited permission, and that needs other configuration to be setup like pf.conf etc to use which I am not able to
configure, thus that possibility is ruled out.
Packet filtering with lsm-pf is different from the BPF API. However BPF is still going to require root access.
I tried the method you suggested, as I verified by checking for 'ls /alt1' and 'ls /alt2' but I am not sure that they
are still in same layer, as when I tried I got following o/p:
I tried to ping 192.168.2.14 (wm0 interface).
# SOCK=/alt2 ping 192.168.2.14
PING 192.168.2.14 (192.168.2.14): 56 data bytes
ping: sendto: No route to host
here '/alt2' is assigned to en1 ( physically USB to ethernet dongle) with IP as 192.168.3.11
Both the interfaces are physically connected.
This doesn't works for me.
Any suggestions will be helpful in this respect?
Prashant
