09/14/2009 9:19 AM
post37883
What can learn from a system that shows 5000 Squelch Test errors (6.4.1 e1000) out of 500millions packets. I've never
seen that error before. It's present on 2 PC out of 6 that are connected to the same switch. Cable length is in the 20
feet range.
09/14/2009 9:27 AM
post37884
I think I mentioned this last week ...
In an attempt to better diagnose the source of
lost packets, I overloaded the now-unused SQE
counter.
See, you can either lose packets because you
run out of descriptors (the nic was able to
buffer the packet, but there was no cpu ram
available) OR the nic was unable to buffer the
packet because it overran it's internal rx fifo.
Previous drivers added the two together, which
annoyed me.
So, I reused SQE for internal rx fifo overruns,
which generally indicates excessive bus latency,
or perhaps misconfigured link-level flow control,
or even misconfigured rx fifo watermarks.
I will now walk down to the parking lot and break
off a car antenna and whip myself in exculpation :-)
We should probably document this somewhere, to
reduce the number of lacerations on my back ...
aboyd www.PoweredByQNX.com/images/L39x2.jpg
09/14/2009 9:40 AM
post37891
> From: Andrew Boyd [mailto:community-noreply@qnx.com]
> Sent: Monday, September 14, 2009 9:27 AM
> To: drivers-networking
> Subject: RE: Squelch Test errors
> counter.
> annoyed me.
That sounds bad. There was 5000 Squelch Test errors, and around 4000 "Packets Dropped on received". I through I added
some tx and rx descriptor but looks like this one slipped through. Just that, I'm hoping this will get rid of the rx
interface fifo overrun...
There are people at QNX who have cars that are that old?
> Networking Drivers
> http://community.qnx.com/sf/go/post37884
09/14/2009 9:54 AM
post37895
So, you had 5000 rx packets lost because of rx fifo
overruns, and 4000 rx packets lost because the rx
descriptor ring was full.
Increase the size of your "receive=X" command line
option to the driver to get rid of the rx descriptor
packet losses.
You lost (rougly) 10,000 packets out of 500 million,
which is one lost rx packet every 50,000, which isn't
bad, but isn't perfect - very occasionally, you will
see a hiccup as the network protocol times out and
re-transmits.
Actually, I just broke 500,000 km on my 2001 Honda
Civic. I want to video the odometer rolling over
ONE MEELLION kilometers for youtube :-)
I'm wondering - will the odometer just go blank?
Will it go back to zero? Will it display an error?
Perhaps exponential notation?
aboyd
09/14/2009 10:35 AM
post37901
> Sent: Monday, September 14, 2009 9:54 AM
> packet losses.
Hum it's to 4096 and just got 191 Packets Dropped on received
And 78 squelch Test errors, something isn't right. Out of 10Million packet.
Another machine has 703 packet dropped and 283 sequel error out of also 11 million packet.
Will keep on digging. Thanks
09/14/2009 10:48 AM
post37903
> it's to 4096
Hm. Just checked the source and both devnp-e1000
and devnp-i82544 limit rx to 2048. I wonder if
there is some underlying hardware limitation?
> and 78 squelch Test errors
that's around 1 in 90,000 rx packet dropped,
which again isn't perfect, but isn't really
that bad, either.
> out of 11 million packet.
1 in 11,000 - not bad, but not great either.
With a big enough rx descriptor ring, you
ought to be able to straddle your scheduling
latency of io-pkt and entirely get rid of the
"dropped" errors, unlike you've got something
that really hogs the cpu at a very high priority
for a lengthy time.
The SQE (rx fifo) errors may be a bit trickier
to eradicate - first, you have to figure out
the exact cause.
aboyd
09/14/2009 10:54 AM
post37904
You can also check to see if any other devices are on the same interrupt
line and slay their drivers to see if the situation improves.
Sent: Monday, September 14, 2009 10:49 AM
> it's to 4096
that bad, either.
for a lengthy time.
the exact cause.
aboyd
Networking Drivers
http://community.qnx.com/sf/go/post37903
09/14/2009 11:00 AM
post37907
Right! Sharing interrupts is definitely to be avoided
if at all possible:
http://community.qnx.com/sf/wiki/do/viewPage/projects.networking/wiki/Dr
ivers_wiki_page
and scroll down to:
-- cut --
Shared Interrupts - Problems?
Different devices sharing a hardware interrupt is kind of a neat idea,
but unless you really need to do it - because you've run out of hardware
interrupt lines - it generally doesn't help you much. In fact, it can
cause you trouble. For example, if your driver doesn't work - e.g. no
received packets - check and see if it is sharing an interrupt with
another device, and if so, re-configure your board so it does not. Most
of the times, when shared interrupts are configured, there is no good
reason for it - i.e. you haven't really run out of interrupts - and this
can decrease your performance, because when the interrupt fires, ALL of
the devices sharing the interrupt need to run and check and see if it is
for them. If you check the source, you can see that some drivers do the
"right thing" which is to read registers in their interrupt handlers to
see if the interrupt is really for them, and ignore it if not. But many,
many drivers do not - they schedule their thread-level event handlers to
check their hardware, which is inefficient and reduces performance. If
you are using PCI bus, use the "pci -v" utility to check interrupt
allocation. You may be surprised as to what you see. Another point worth
making is that sharing interrupts can vastly increase interrupt latency,
depending upon exactly what each of the drivers do. Remember that after
an interrupt fires, it will NOT be re-enabled by the kernel until ALL
driver handlers tell the kernel that they have completed handling. So,
if one driver takes a long, long time servicing a shared interrupt which
is masked, if another device on the same interrupt causes an interrupt
during that time period, processing of that interrupt can be delayed for
an unknown duration of time. Bottom line is that interrupt sharing can
cause problems, and reduce performance, increase cpu consumption, and
seriously increase latency. Unless you really need to do it, don't. If
you must share interrupts, make sure your drivers are doing the "right
thing". Face it - shared interrupts are the new "trans fats" :-)
-- cut --
P.S. Took at peek at the intel doc, it mentions an
internal limit of 64k for rx descr ring size. Looked
at the BSD (wm) driver, it's hardcoded to 256!
I suspect we should bump up the rx max descr ring from
2048 to 4096 in both devnp-e1000 and devnp-i82544.
aboyd
09/14/2009 11:56 AM
post37918
Thanks for the suggestion Hugh. Interrupt is not shared and priority of the event thread is set to 100. Just checked
with pidin and none of io-pkt thread's priority are above 21, that's odd?
Io-pkt-v4 -de1000 transmit=4096 receive=4096 priority=100 -pqnet no_slog=1
None of our process are above priority 20. Machine is Quad Core running at 2.3G.
> From: Hugh Brown [mailto:community-noreply@qnx.com]
> Sent: Monday, September 14, 2009 10:54 AM
> interrupt
> > it's to 4096
> that bad, either.
> for a lengthy time.
> the exact cause.
> aboyd
> Networking Drivers
> Networking Drivers
> http://community.qnx.com/sf/go/post37904
09/14/2009 1:29 PM
post37924
io-pkt can be a bit slippery as to which thread
(and what priority) you end up executing, depending
upon receive and transmit paths, multi-core,
client calls, traffic on other ports, etc. Your
"priority=100" is supposed to be passed to the
interrupt_entry_init() call, but ...
I might suggest that you run the following:
# top -p 255
then do a big ttcp test. What priority are the
io-pkt threads really running at?
P.S. PR71200 created to track the request to bump
the max rx descr size from 2048 to 4096 for both
IMHO 4096/4096 should be the default max values
for tx/rx for all gige drivers, hardware permitting.
aboyd
09/14/2009 2:54 PM
post37937
> Sent: Monday, September 14, 2009 1:29 PM
> # top -p 255
Can't do it for now (this problem is at a customer site).
I use the System Profiler and from what I can see when thread 2 of io-pkt-v4 receive the pulse send by the ISR, and the
priority of the thread stays at 21.
> aboyd
> Networking Drivers
> http://community.qnx.com/sf/go/post37924
09/14/2009 3:02 PM
post37940
> send by the ISR, and the priority of the thread
> stays at 21.
Ah ha. Threading (and thus priority) in io-pkt is
outside the scope of the driver, unlike in io-net,
where the driver manually created the rx thread.
This can get pretty complicated. As far as the
threading priority goes for any given configuration
of X processors and Y interfaces, I think you
probably need to talk to Seanb.
aboyd
09/14/2009 3:15 PM
post37943
Sean care to comment?
> Sent: Monday, September 14, 2009 3:02 PM
> > stays at 21.
Then why the priority argument support by the driver? Another job for Super Steve ? ( said with a super hero sound)
Sean?
> aboyd
> Networking Drivers
> http://community.qnx.com/sf/go/post37940
09/14/2009 3:20 PM
post37944
Actually the driver does the "right thing" in that
it sets the default priority (IRUPT_PRIO_DEFAULT)
and allows the user command line option to override
it, and then passes it down to interrupt_entry_init()
which is all as it should be.
aboyd
09/14/2009 3:23 PM
post37946
> Sent: Monday, September 14, 2009 3:21 PM
The doc says: "The priority of the driver's event-handler thread (default 21)."
> aboyd
> Networking Drivers
> http://community.qnx.com/sf/go/post37944
09/14/2009 3:27 PM
post37950
Important Note: In io-net, the driver created the rx thread.
In io-pkt, the driver does NOT create the rx thread - instead,
it passes the priority to interrupt_entry_init() as specified.
AFAIK there is nothing else that the driver is capable of
doing with respect to the priority in the io-pkt infrastructure.
aboyd
09/14/2009 3:04 PM
post37941
I see that io-pkt-vX has the following "-p tcpip" options:
rx_prio
rx_pulse_prio
You probably should look at these.
aboyd
09/14/2009 3:23 PM
post37948
Thanks will give that a try.
> Sent: Monday, September 14, 2009 3:05 PM
> rx_prio
> rx_pulse_prio
> aboyd
> Networking Drivers
> http://community.qnx.com/sf/go/post37941
Re: RE: Squelch Test errors
09/14/2009 3:23 PM
post37947
> event thread is set to 100. Just checked with pidin and none of io-pkt
> 3G.
Just so we are all clear.
I see spaces between the options, those are suppose to be comma connected, right? Ie, it suppose to be:
io-pkt-v4 -de1000 transmit=4096,receive=4096,priority=100 -pqnet no_slog=1
-xtang
RE: RE: Squelch Test errors
09/14/2009 3:25 PM
post37949
> no_slog=1
Aaarrrrrrrrrrrrrgggghhhhhhh.
> -xtang
> Networking Drivers
> http://community.qnx.com/sf/go/post37947
09/14/2009 9:34 AM
post37888
PR 71191 created and assigned to the tireless Steve
Reid to document this in the devnp-e1000 and devnp-i82544
driver notes.
aboyd
09/14/2009 9:35 AM
post37889
May I suggest that the string (Squehch Test errors) in nicinfo be changed ?
> Sent: Monday, September 14, 2009 9:35 AM
> driver notes.
> aboyd
> Networking Drivers
> http://community.qnx.com/sf/go/post37888
