Forum Topic - TAP interface: (5 Items)
TAP interface
Hi All,
is there a way to assign a TAP device to an individual ethernet interface ??
Cheers
--Armin
Re: TAP interface
On Fri, Jun 28, 2013 at 02:37:00PM -0400, Armin Steinhoff wrote:
> Hi All,
No.  The question doesn't make much sense.  When a tap is
configured, there's a /dev/tapX and a corresponding tapX
pseudo interface.  Packets written to /dev/tapX appear
as if they were received on input on the tapX interface,
packets that arrive for transmit on the tapX interface can
be read() off the /dev/tapX device.  Normal ip routing
occurs on packets to / from the tapX interface.
Re: TAP interface
>> Hi All,
you mean
ifconfig tap0 create
ifconfig tap0 up
ifconfig tap0 11:22:33:44:55:66
ifconfig tap0 11:22:33:44:55:66 active
makes no sense ? Or do I have to assign an IP address??
I want simply to send/receive by one of the dual ethernet interface!
What semantic have the "pre-created" tap0 to tap3 devices ??
Why is it not possible to set the O_NONBLOCK flag on a TAP device ??
--Armin
>   When a tap is
> Regards,
> -seanb
> Networking Drivers
> http://community.qnx.com/sf/go/post102779
> To cancel your subscription to this discussion, please e-mail drivers-networking-unsubscribe@community.qnx.com
Re: TAP interface
> >> Hi All,
> you mean
> ifconfig tap0 up
Yes, that makes sense.  Here you're manipulating
the pseudo tap interface, not a real ethernet interface.
Only if you want to do IP over it.
It is possible.
> --Armin
> >   When a tap is
> > Regards,
> > -seanb
> > Networking Drivers
> Networking Drivers
> http://community.qnx.com/sf/go/post102790
Re: TAP interface
>> Hi All,
> pseudo interface.
 ... and what is the "tapX pseudo interface". What is the path of this
virtual "pseudo interface"?
After e.g. "ifconfig tap0 create" there is no new device created! But
after "ifconfig tap0 up"
 it is possible to open "/dev/tap0" sucessfully.
So what is your strange "pseudo tapX interface" ??
Is you TAP interface not intended to replace a "RAW socket interface" ??
--Armin
> Regards,
> -seanb
> Networking Drivers
