82577 Sporadic Link Issue
08/04/2011 9:22 AM
post87815
We are currently running QNX 6.5.0 on a Calpella platform with QM57 chipset.
We are using the integrated 82577 ethernet controller to connect to the
network. We find that sometimes the link does not get detected during system
start up. The network cable is always connected to 82577 with IP address
allocated statically. On running ifconfig or nicinfo, the status of link is
down with no packets txed/rxed. When the ethernet controller is in this
state, if I bring the interface up by issuing "ifconfig wm0 up" with wm0
being the 82577 , then everything springs back to action and then there is
no issue in communicating over the network. Hence the issue seems to be only
with the startup link. Please note that this does not always happen as I
had kept a script running to reproduce this issue wherein in rc.local, all I
was doing is trying to ping to external machine and if the ping is
successful then reboot the board or else proceed and boot to prompt. With
this script running, I am getting failure may be once in five times.
I have applied the following patches but with no success:
patch-650-2338-RS3775_x86-650-updates.tar
patch-650-2530-io-pkt.tar
Also I tried using the driver provided in the following link but again with
no success:
http://community.qnx.com/sf/discussion/do/listPosts/projects.networking/disc
ussion.drivers.topc20387
I have attached the "pci -v", "sloginfo", "ifconfig -a" and "nicinfo" dumps
when this issue occurs. We would appreciate if you could please help us
debug this issue. Please let me know incase any more information is needed.
Girish
Re: 82577 Sporadic Link Issue
08/04/2011 10:12 AM
post87817
Additionally, I have even tried the driver provided at the following link with no success:
http://community.qnx.com/sf/discussion/do/listPosts/projects.bsp/discussion.bsp.topc20644
On the platform I am running, we also have another 82574L network controller. The issue described above is not seen on
this interface.
08/04/2011 10:52 AM
post87819
Please try the attached driver and let me know if it solves the problem.
Thanks, Hugh.
Hugh Brown (613) 591-0931 ext. 2209 (voice)
QNX Software Systems Limited. (613) 591-3579 (fax)
175 Terence Matthews Cres. email: hsbrown@qnx.com
Kanata, Ontario, Canada.
K2M 1W8
08/04/2011 12:06 PM
post87821
Thanks for the response.
Nope, this driver did not solve the issue. I have attached sloginfo dump but this time enabled with full verbose option.
The dump shows the debug prints during bootup wherein we do not get any link and once on the prompt the link coming up
after executing "ifconfig wm up".
Let me know incase any additional information is needed.
Girish
08/04/2011 12:51 PM
post87823
When this problem occurs, is the link light on both the switch and the
adapter on? When you run ³ifconfig wm0 up², does the link light go off and
then come back on again?
Thanks, Hugh.
> this time enabled with full verbose option. The dump shows the debug prints
> coming up after executing "ifconfig wm up".
> Girish
> Networking Drivers
> http://community.qnx.com/sf/go/post87821
K2M 1W8
08/04/2011 1:39 PM
post87826
Yes, the link light is ON on both the adapter and switch. Also when I do a ifconfig up , the link does not go off and on
but remains on. One thing to note is that when things work, the default speed with which the adapter comes up is 10
Mbps and when the driver is instantiated with the interface being made active, the link changes to 100 Mbps ( I am using
10/100 netgear switch ). But when we see the issue, the adapter remains at 10 Mbps. Also when I do a ifconfig up, the
speed still remains at 10 Mbps although I can communicate with the external world.
Girish
08/04/2011 1:51 PM
post87827
Sorry let me take one statement back, when I do ifconfig up, the link LED does go off and come back on again and gets
negotiated to 100 Mbps
08/04/2011 2:22 PM
post87828
Another observation is that with the latest driver provided today , when I do ifconfig up, the link does not go down and
up ie the link led remains ON with just the ifconfig status showing active after executing the command.
08/04/2011 4:03 PM
post87829
We made a change to the latest driver so that the link isn¹t reset when an
ifconfig up is sent, so that is why you don¹t see the link go down and then
up again.
Please can you give me the same output as before with the driver running in
verbose mode when the problem occurs, and then the output after the ifconfig
up is run.
Many thanks, Hugh.
> ifconfig up, the link does not go down and up ie the link led remains ON with
> Networking Drivers
> http://community.qnx.com/sf/go/post87828
K2M 1W8
08/05/2011 4:39 AM
post87840
I have attached the sloginfo with full verbose as requested by you when the issue occurs followed by ifconfig up which
fixes the issue with the latest driver.
08/05/2011 8:13 AM
post87848
Thanks for your patience. I have added some debug to the link routine in the
driver, so will you please run the attached driver as before and send me the
sloginfo output again. Before doing this, if you could please ³slay slogger²
and restart it with ³slogger s128k².
Many thanks, Hugh.
> issue occurs followed by ifconfig up which fixes the issue with the latest
> driver.
> Networking Drivers
> http://community.qnx.com/sf/go/post87840
K2M 1W8
08/05/2011 11:29 AM
post87860
Sorry for the delay as was not on my place. Please find the sloginfo debug log attached. Let me know if you need
anything or if you want me to try anything.
Girish
08/08/2011 3:57 AM
post87877
Additionally I checked out this issue in another QM57 based platform that we have wherein we use the same 82577 ethernet
controller and I was able to reproduce the issue even on that platform. This check was just to ensure that the problem
is not platform specific.
As this is a customer faced issue, we are currently seeing if we can provide some workaround for the time being until we
can find a proper fix.
Girish
08/08/2011 7:45 AM
post87885
What make of board is this with the QM57 chipset?
> have wherein we use the same 82577 ethernet controller and I was able to
> the problem is not platform specific.
> some workaround for the time being until we can find a proper fix.
> Regards,
> Girish
> Networking Drivers
> http://community.qnx.com/sf/go/post87877
K2M 1W8
08/08/2011 7:52 AM
post87887
Both these platforms are Concurrent Technologies SBCs. Also these interfaces are verified to operate as expected with
other OSes.
08/10/2011 3:49 AM
post87958
Hugh, is there anything else we can try to corner this issue as without the driver sources we are quite limited in what
debugging we can do to resolve this issue. We have got the ball rolling to get hold of the e1000 driver sources but
knowing that we have to go through the red tape it might take sometime. We would appreciate if you can provide us with
some pointers in the mean time if possible as incase we do get to a solution then we do not need to go through the
follow up cycles to get hold of the sources. Thanks for all your assistance.
08/10/2011 7:41 AM
post87968
Girish,
The link up/down logic in the e1000 driver is driven by interrupts and it
appears as though the link interrupt is not happening intermittently, so
when you do an ³ifconfig wm0 up² the interrupt comes through and the link is
marked as up. Why this is only happening on the 82577 chip, I have no idea.
I have tried the driver on all the other hardware that I have, without any
problem, so it appears to be limited to this one chipset. Without the
hardware it is very difficult to debug.
Hugh.
> driver sources we are quite limited in what debugging we can do to resolve
> sources but knowing that we have to go through the red tape it might take
> sometime. We would appreciate if you can provide us with some pointers in the
> to go through the follow up cycles to get hold of the sources. Thanks for all
> your assistance.
> Networking Drivers
> http://community.qnx.com/sf/go/post87958
K2M 1W8
08/10/2011 8:02 AM
post87970
Hugh,
I understand as if you do not have a 82577 platform it will be difficult to fix this issue. I hope Garry is able to
provide us with the sources soon so that we can take it forward and provide you with some feedback.
Girish
08/10/2011 10:25 AM
post87980
Girish,
Please will you try the attached driver and let me know whether it makes any
difference. I found something that might be causing the problem, but am not
sure until it is tested.
Thanks, Hugh.
On 11-08-10 8:02 AM, "Girish Shirasat" <community-noreply@qnx.com> wrote:
> Hugh,
> fix this issue. I hope Garry is able to provide us with the sources soon so
> Girish
> Networking Drivers
> http://community.qnx.com/sf/go/post87970
K2M 1W8
08/10/2011 10:39 AM
post87982
Sorry, that one doesn¹t work! Please try this one.
Thanks, Hugh.
> Hugh,
> Girish
> Networking Drivers
K2M 1W8
08/10/2011 12:54 PM
post87986
Hi Hugh
I just been looking into the issue now.
The latest driver you have sent us does not fix the issue. I have attached the log files:
10Augbif - sloginfo after failure to bringup link on 82577
10Augaf - sloginfo after ifconfig up after failure
ifcnfg - ifconfig output wm2 is 82577.
Hope the logs provide more insight to you.
Regards
Jaychander
08/11/2011 9:06 AM
post88009
I have added some more debug to the driver, so please will you run this
version and send me the sloginfo output as before.
Thanks, Hugh.
On 11-08-10 12:54 PM, "Jaychander Thiru" <community-noreply@qnx.com> wrote:
> Hi Hugh
> log files:
> Regards
> Jaychander
> Networking Drivers
> http://community.qnx.com/sf/go/post87986
K2M 1W8
08/11/2011 12:40 PM
post88021
Attached is the sloginfo with the latest driver. Thanks for sticking with this issue Hugh.
Girish
08/11/2011 12:54 PM
post88023
Are you sure that you are running the driver I sent you today? I don¹t see
any of my debug in the sloginfo.
Hugh.
> issue Hugh.
> Girish
> Networking Drivers
> http://community.qnx.com/sf/go/post88021
K2M 1W8
08/11/2011 1:25 PM
post88026
Yes, I think so. Just to be sure, I downloaded it again and used it and I am getting same debug outputs.
Girish
