AW: SystemProfiler - Changed Statistics for SMP traces
09/07/2009 2:30 AM
post37444
I agree absolutely with HP. Indeed, for me the CPU time analysis is like looking at fuel consumption, i.e. CPU-cycle
consumption.
The question is: which process consumes how much of the CPU?
I find it pretty awkward that in a SMP system now the 'running' time of a process may significantly vary between test
runs (of the identical test case), just because the threads are running more or less in parallel.
I strongly support HP's proposal (separate result for 'realtime execution duration' or at least a preference option
which value the process summary should represent).
All other states show in process summary view the sum of the threads states. It is quite a violation of consistency to
define a different summary function for the running state.
Daniel
>Von: Hans-Peter Reichert [mailto:community-noreply@qnx.com]
>Gesendet: Sonntag, 6. September 2009 09:29
>An: general-ide
>Betreff: SystemProfiler - Changed Statistics for SMP traces
>I want to start a discussion about the changed behaviour of
>System Profiler Statistics on traces from SMP systems.
>Has anybody else realized that stats have changed?
>Let me show you a short example for how stats are now working:
>Example 1:
>Process A with Thread 1 and 2, running on two cores
>A(T1) running from second 0-2 on core 1
>A(T2) running from second 1-3 on core 2
>If you select Process A you get a running time of 3s(!)
>whereas when you select T1 and T2 you get 4s of running time.
>Let me change example 1 a bit:
>A(T2) running from second 2-4 on core 2
>Now, when you select Process A you get 4s of running time, the
>same as you will get when you select T1 and T2.
>The behaviour of stats when selecting the process line has
>changed, in older versions it was just the same number as for
>all threads of a process.
>So what do you think about this change?
>In my oppinion this is inconsistent.
>If you want something like this, you should add a new result
>called something like "realtime execution"
>CPU time or running time is like fuel consumption of a car.
>1 Car driving 2 times from A to B will allways give you the
>same amount of used fuel as when you have two cars driving 1
>time from A to B. (1 core vs. 2 cores)
>The "General Stats" has been one of my favorites in starting
>analysis of kernel traces.
>It will get horrible to use for me in future if this will keep
>unchanged.
>If not the mentioned additional result line will be added, at
>least this behaviour should be configurable through a
>perfernces attribute.
>what do you think?
>/hp
>General
>http://community.qnx.com/sf/go/post37436
Re: SystemProfiler - Changed Statistics for SMP traces
10/13/2009 10:59 PM
post39852
+1 from me ... though the other values are interesting at times too ...
I hate not having information.
Thomas
Hans-Peter Reichert wrote:
> I want to start a discussion about the changed behaviour of System Profiler Statistics on traces from SMP systems.
> Example 1:
> the same as you will get when you select T1 and T2.
> The behaviour of stats when selecting the process line has changed,
> in older versions it was just the same number as for all threads of a process.
> If you want something like this, you should add a new result called something like "realtime execution"
> 1 Car driving 2 times from A to B will allways give you the same amount of used fuel as
> when you have two cars driving 1 time from A to B. (1 core vs. 2 cores)
> The "General Stats" has been one of my favorites in starting analysis of kernel traces.
> It will get horrible to use for me in future if this will keep unchanged.
> If not the mentioned additional result line will be added, at least this behaviour should be configurable
> through a perfernces attribute.
> what do you think?
> /hp
