Forum Topic - Invalid .kev file.: (4 Items)
Invalid .kev file.
I attached a .kev file the IDE chokes on, either version 4.7.0 or 4.6.0.  The file comes from a QNX6.4.1 machine.
I'm guessing it's an hardware problem of some sort because on an other machine, which has the same config, it works ok.
 At anyrate you could use to file to make the system profiler more robust.
Not sure if it's related or not but pidin info report 2 cores to be of different speed then 2 other core ( it's a quad
core machine)!!!  I'll be looking into that.
Attachment: Compressed file testbench-trace-090814-133034.zip 806 KB
AW: Invalid .kev file.
I checked that file with traceprinter.
That's working fine, so the trace itself seams not to be corrupted
at structure level, but maybe on a semantical one.
I tried it with my 4.6.1 20090619, after 15 minutes of "trace normalization"
it fails with NullPointerException without a callstack.
So think it's an IDE issue.
-----Ursprüngliche Nachricht-----
Von:	Mario Charest [mailto:community-noreply@qnx.com]
Gesendet:	Fr 14.08.2009 19:40
An:	general-ide
Cc:
Betreff:	Invalid .kev file.
General
http://community.qnx.com/sf/go/post36042
Attachment: Text winmail.dat 3.58 KB
RE: Invalid .kev file.
> From: Hans-Peter Reichert [mailto:community-noreply@qnx.com]
> Sent: Friday, August 14, 2009 2:09 PM
> To: general-ide
> Subject: AW: Invalid .kev file.
> That's working fine, so the trace itself seams not to be corrupted at
> normalization"
We found why the cores were running at different frequencies (BIOS setting). After correcting that the System Profiler
worked as expected.  So yes the trace isn't corrupted but its content is not right. I'm guessing the timestamps are
totally out to lunch.
> An:	general-ide
> Cc:
> machine, which has the same config, it works ok.  At anyrate you could
> different speed then 2 other core ( it's a quad core machine)!!!  I'll
> Mauser Chairman of the Supervisory Board: Ansgar Rempp | Domicile:
> Karlsbad | Local Court Mannheim: Register No. 361395
> Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-
> Absender und loeschen Sie diese Mail. Das unerlaubte Kopieren sowie die
> you are not the intended recipient (or have received this e-mail in
> unauthorized copying, disclosure or distribution of the contents in
> http://community.qnx.com/sf/go/post36047
Re: Invalid .kev file.
Thanks Mario.
Yes, tracelogger creates semantically incorrect data when there are hardware issues related to the CPU clocks.
Traceprinter doesn't have any issues with these traces because it doesn't attempt to reorder the data and interpret it.
It simply dumps the contents of each event as is. During the repair process IDE attempts to properly order the events in
 the trace file which can go awry when the timestamp data is incorrect.
There is a bug report open to improve the user experience in the IDE when these types of traces are encountered and to
present the user with a more relevant error message than a NullPointerException.
