Forum Topic - Target File System Navigator Woes: (3 Items)
4.6.0 beta.  I click on the down arrow in the Target File System Navigator to change what column was display.  After
doing so everything in the right windows ( file list ) when away.  I could still copy file to it but it stays empty.  I
try enabling back the column, but no go.
I have found that if I resize the file list windows and then change the column setting it would refresh properly.
Would be nice if the target navigator had an address bar of some sort that we could type the path in.
Re: Target File System Navigator Woes
There is bug that we still cannot fix that sometime all columns become 0 size. To fix that open propertires for column
selection and click ok.
I can enter enhancement request about having file path (is it like because it hard to expand the tree?)
> http://community.qnx.com/sf/go/post20934
RE: Target File System Navigator Woes
> Sent: January-28-09 11:54 AM
> To: general-ide
> Subject: Re: Target File System Navigator Woes
> 0 size. To fix that open propertires for column selection and click ok.
By properties column I assume you mean the "Table Parameters". If that is the case clicking ok does nothing.  I have to
resize nd then change the column setting.
Yes I have to click/scroll/click/scroll/... I've reduce the scrolling by maximizing the view first and restore it when
I'm done.
While I'm at it, would be nice if the "future"file path had some sort of history.  Also when the IDE is restarted I
would save time if the TFSN would show the same tree/path as when I closed it.
Cheers,
> Navigator to change what column was display.  After doing so everything
> to it but it stays empty.  I try enabling back the column, but no go.
> > General
> http://community.qnx.com/sf/go/post20936
