Forum Topic - Problem with PROJECT_ROOT references: (18 Items)
Hello
I seem to be having a problem with referencing include files in other projects.  I have added them in using the project
preferences, but it seems to be getting confused on some of them.  Here is a snippet from the common.mk:
#===== EXTRA_INCVPATH - a space-separated list of directories to search for include files.
EXTRA_INCVPATH+=$(PROJECT_ROOT)/public  \
	$(PROJECT_ROOT_zoneManager)/public  \
	$(PROJECT_ROOT_alarmManager)/public  \
	$(PROJECT_ROOT_buttonMgr)/public  \
	$(PROJECT_ROOT_uCcommon)/public  \
	$(PROJECT_ROOT_historyManager)/public  \
	$(PROJECT_ROOT_tricolorLedMgr)/public  \
	$(PROJECT_ROOT_auxPowerMgr)/public  \
	$(PROJECT_ROOT_piezoManager)/public  \
	$(PROJECT_ROOT_hardwiredZones)/public  \
	$(PROJECT_ROOT_diagManager)/public  \
	$(PROJECT_ROOT_gprsManager)/public  \
	$(PROJECT_ROOT_tamperButtonMgr)/public  \
	$(PROJECT_ROOT_audioManager)/public  \
	$(PROJECT_ROOT_upgradeManager)/public  \
	$(PROJECT_ROOT_boschSensors)/public  \
	$(PROJECT_ROOT_boschZones)/public  \
	$(PROJECT_ROOT_tsHandler)/public  \
	$(PROJECT_ROOT_cgiEventListener)/public  \
	$(PROJECT_ROOT_pwrSupplyMgr)/public  \
	$(PROJECT_ROOT_troubleManager)/public  \
	$(PROJECT_ROOT_cameraManager)/public  \
	$(PROJECT_ROOT_boschKeyfob)/public  \
	$(PROJECT_ROOT_commManager)/public  \
	$(INSTALL_ROOT_nto)/include $(PROJECT_ROOT_ucmgr)/public
And here is a snippet of the build output:
C:/QNX/QNX640/host/win32/x86/usr/bin/qcc -V4.2.4,gcc_ntoarm -c  -Wc,-Wall -Wc,-Wno-parentheses -Wc,-fno-builtin
    -I. -IC:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/ucalarm/arm/so.le -IC:/Users/rdowdall/Documents/
Workspaces/ide-4.5-workspace/ucalarm/arm/so-le-g -IC:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/ucalarm/arm
-IC:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/ucalarm -IC:/Users/rdowdall/Documents/Workspaces/ide-4.5-
workspace/ucalarm/public -I/../../../zoneManager/public -I/../../../alarmManager/public -I/../../../buttonMgr/public -IC
:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/uCcommon/public -I/../../../historyManager/public -I/../../../
tricolorLedMgr/public -I/../../../auxPowerMgr/public -I/../../../piezoManager/public -I/../../../hardwiredZones/public -
I/../../../diagManager/public -I/../../../gprsManager/public -I/public -I/../../../audioManager/public -I/../../../
upgradeManager/public -I/../../../boschSensors/public -I/../../../boschZones/public -I/../../../tsHandler/public -I/../.
./../cgiEventListener/public -I/../../../pwrSupplyMgr/public -I/../../../troubleManager/public -I/../../../cameraManager
/public -I/../../../boschKeyfob/public -I/../../../commManager/public -IC:/QNX/QNX640/target/qnx6/include -I/../../../
ucmgr/public -IC:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/ucalarm/public -IC:/QNX/QNX640/target/qnx6/usr/
include      -EL  -g  -shared     -DVARIANT_so -DVARIANT_le -DVARIANT_g -DBUILDENV_qss  C:/Users/rdowdall/Documents/
Workspaces/ide-4.5-workspace/ucalarm/cgiSession.c
It would appear that some of the PROJECT_ROOT stuff is undefined because the -I starts with a /
It picked up one of them though, which I find weird.
Am I doing something wrong?
Rodney
Re: Problem with PROJECT_ROOT references
Is this IDE 4.5?
Rodney Dowdall wrote:
> Hello
project preferences, but it seems to be getting confused on some of them.  Here is a snippet from the common.mk:
rs/public -I/../../../boschZones/public -I/../../../tsHandler/public -I/../../../cgiEventListener/public -I/../../../
pwrSupplyMgr/public -I/../../../troubleManager/public -I/../../../cameraManager/public -I/../../../boschKeyfob/public -I
/../../../commManager/public -IC:/QNX/QNX640/target/qnx6/include -I/../../../ucmgr/public -IC:/Users/rdowdall/Documents/
Workspaces/ide-4.5-workspace/ucalarm/public -IC:/QNX/QNX640/target/qnx6/usr/include      -EL  -g  -shared     -
DVARIANT_so -DVARIANT_le -DVARIANT_g -DBUILDENV_qss  C:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/ucalarm/
cgiSession.c
> Thanks,
> Rodney
> http://community.qnx.com/sf/go/post17866
Yep.  It's:
Version: 4.5.0
Build id: I20081019
Could you also insert the following line at the end of common.mk:
$(warning PROJECT_ROOT_zoneManager = $(PROJECT_ROOT_zoneManager))
On 03/12/2008 3:31 PM, Rodney Dowdall wrote:
> Yep.  It's:
> Version: 4.5.0
> Build id: I20081019
> http://community.qnx.com/sf/go/post17868
Rodney,
Unsuccessfully tried to reproduce the problem. Could you please paste
into your reply environment?
Alex
On 03/12/2008 2:40 PM, Rodney Dowdall wrote:
> Hello
> Thanks,
> Rodney
QNX 6.4 on Windows Vista.
Sorry, I asked you about output of set command :-). But the fact that it
is Vista is also very interesting.
> http://community.qnx.com/sf/go/post17870
Gotcha!
Add NEED_VPATH_MUNGING= to the beginning of your common.mk. It seems to
me that it helps.
Alex
I added the NEED_VPATH_MUNGING= to the beginning of the common.mk and this happened:
C:\QNX\QNX640\host\win32\x86\usr\bin\make -k all --file=C:/Users/rdowdall/AppData/Local/Temp/QMakefile122833789655417764
.tmp
C:/QNX/QNX640/host/win32/x86/usr/bin/make -j 1 -Carm -fMakefile all
make[1]: Entering directory `C:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/ucalarm/arm'
C:/QNX/QNX640/host/win32/x86/usr/bin/make -j 1 -Cso-le -fMakefile all
process_begin: CreateProcess((null), /bin/pwd, ...) failed.
make[2]: *** No rule to make target `activation.o', needed by `C:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/
ucalarm/arm/so-le/libucalarm.so'.
make[2]: *** No rule to make target `alarm.o', needed by `C:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/
make[2]: Entering directory `C:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/ucalarm/arm/so-le'
make[2]: Leaving directory `C:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/ucalarm/arm/so-le'
make[2]: *** No rule to make target `arm.o', needed by `C:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/ucalarm
make[2]: *** No rule to make target `audio.o', needed by `C:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/
make[2]: *** No rule to make target `boschKeyfobs.o', needed by `C:/Users/rdowdall/Documents/Workspaces/ide-4.5-
workspace/ucalarm/arm/so-le/libucalarm.so'.
make[2]: *** No rule to make target `boschSensors.o', needed by `C:/Users/rdowdall/Documents/Workspaces/ide-4.5-
make[2]: *** No rule to make target `boschZones.o', needed by `C:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/
make[2]: *** No rule to make target `buttons.o', needed by `C:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/
make[2]: *** No rule to make target `cameras.o', needed by `C:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/
make[2]: *** No rule to make target `cgiEvents.o', needed by `C:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/
make[2]: *** No rule to make target `cgiSession.o', needed by `C:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/
make[2]: *** No rule to make target `commManager.o', needed by `C:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace
make[2]: *** No rule to make target `diag.o', needed by `C:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/
make[2]: *** No rule to make target `disarm.o', needed by `C:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/
make[2]: *** No rule to make target `events.o', needed by `C:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/
make[2]: *** No rule to make target `formatting.o', needed by `C:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/
make[2]: *** No rule to make target `gprs.o', needed by `C:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/
make[2]: *** No rule to make target `history.o', needed by `C:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/
make[2]: *** No rule to make target `hwZones.o', needed by `C:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/
make[2]: *** No rule to make target `messages.o', needed by `C:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/
make[2]: *** No rule to make target `piezo.o', needed by `C:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/
make[2]: *** No rule to make target `power.o', needed by...
Does it have to be Vista? Just checking....
So it is reproducible on small project with project directory not in workspace?
Don't know for sure, but I assume that Vista is the trigger.  Others are working with the same projects and haven't
noticed a problem, and I think they are using XP.
I can try a small project.  Let me set something up and let you know.
Rodney
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
  <meta content="text/html; charset=ISO-8859-1"
 http-equiv="Content-Type">
</head>
<body bgcolor="#ffffff" text="#000000">
Rodney,<br>
<br>
Why all the paths are munged? I've never seen it before.<br>
<br>
Is there something specific installed on this machine? Cygwin? <br>
<br>
On 03/12/2008 4:13 PM, Rodney Dowdall wrote:
<blockquote
 cite="mid:28796917.1228338818511.JavaMail.sf-admin@community.qnx.com"
 type="cite">
  <blockquote type="cite">
    <pre wrap="">Does it have to be Vista? Just checking....
    </pre>
  </blockquote>
  <pre wrap=""><!---->
  </pre>
    <pre wrap="">So it is reproducible on small project with project directory not in workspace
    </pre>
  </blockquote>
Rodney
General
<a class="moz-txt-link-freetext" href="http://community.qnx.com/sf/go/post17879">http://community.qnx.com/sf/go/
post17879</a>;
  </pre>
</blockquote>
<br>
</body>
</html>
I don't think so....I'll check.  I have some things like Python and Gimp installed, so maybe one of those screwed things
 up .
Rodney
Something is weird on my system.  If I open up bash, and do a cd / I end up in a weird directory.  If I then change dir
in to bin and do a pwd I get a ../../bin as an answer.  I'll uninstall some stuff to see if it could be affecting it.
And once again, looking to the path, I see that before qnx there is some
other suspicious stuff, like PyGTK. Could you please just start IDE with
another environment (QNX  at the beginning of the list)?
Alex
things up .
> Rodney
> http://community.qnx.com/sf/go/post17882
So I uninstalled a bunch of things and I changed my path so that QNX comes after the windows stuff and I still get the
problem.  I think the issue is that the IDE can't do a pwd.  Here is the output from the top of my build:
C:\QNX\QNX640\host\win32\x86\usr\bin\make -k all --file=C:/Users/rdowdall/AppData/Local/Temp/QMakefile122836295859842935
.tmp
C:/QNX/QNX640/host/win32/x86/usr/bin/qcc -V4.2.4,gcc_ntoarm -c -O -Wc,-Wall -Wc,-Wno-parentheses -Wc,-fno-builtin
   -DNDEBUG   -I. -IC:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/ucalarm/arm/so-le -IC:/Users/rdowdall/
Documents/Workspaces/ide-4.5-workspace/ucalarm/arm -IC:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/ucalarm -
IC:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/ucalarm/public -IC:/Users/rdowdall/Documents/Workspaces/ide-4.
5-workspace/zoneManager/public -I/../../../zoneManager/public -I/../../../alarmManager/public -I/../../../buttonMgr/
public -IC:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/uCcommon/public -I/../../../historyManager/public -I/.
./../../tricolorLedMgr/public -I/../../../auxPowerMgr/public -I/../../../piezoManager/public -I/../../../hardwiredZones/
public -I/../../../diagManager/public -I/../../../gprsManager/public -I/public -I/../../../audioManager/public -I/../../
../upgradeManager/public -IC:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/ucmgr/public -I/../../../ucmgr/
public -I/../../../boschSensors/public -I/../../../boschZones/public -I/../../../tsHandler/public -I/../../../
cgiEventListener/public -I/../../../pwrSupplyMgr/public -I/../../../troubleManager/public -I/../../../cameraManager/
public -I/../../../boschKeyfob/public -I/../../../commManager/public -IC:/QNX/QNX640/target/qnx6/include -IC:/Users/
rdowdall/Documents/Workspaces/ide-4.5-workspace/ucalarm/public -IC:/QNX/QNX640/target/qnx6/usr/include      -EL  -shared
   -DVARIANT_so -DVARIANT_le -DBUILDENV_qss  C:/Users/rdowdall/Documents/Workspaces/ide-4.5-workspace/ucalarm/alarm.c
If I open up a bash shell and do /bin/pwd then it works.  If I do it from a command prompt, it doesn't.
Hope this helps.
Rodney
It seems to me as a correct behavior.Windows cannot interpret /bin/pwd
in the way you expect. The question is where does it come from? As long
as we don't have a test case, could you please  do small tests?
1) Let's try to separate IDE and recursive make files. Try to run it
from command line. Even if you not define any macro, it should launch
qcc (which it doesn't now).
2) If it works, try to add at least one macro definition (on command
line for example)
3) If it still works, try to insert $(warning statement as I asked you
before).
Alex
QMakefile122836295859842935.tmp
> Hope this helps.
> Rodney
> http://community.qnx.com/sf/go/post17893
Sorry, I should have posted sooner.  This problem was caused by someone placing some commands in a Makefile further on
down the chain ( in the Arm directory ).  I didn't realize the stuff was in there.  When I took it out, things worked
fine.
