Forum Topic - IDE managed build error: (4 Items)
I may have indicated a problem with this before, but thought I'd post information about my current woes as a data point.
I went to individual files to add a -E option to extra options for the preprocessor.  Once I did this, I started to get
the following:
**** Rebuild of configuration Debug for project phcpp ****
**** Internal Builder is used for build               ****
Build error
org.eclipse.cdt.managedbuilder.internal.core.ResourceConfiguration
Below is an excerpt from the IDE log about this error:
!ENTRY org.eclipse.jface 4 2 2008-11-04 11:34:06.263
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jface".
!STACK 0
java.lang.ClassCastException: org.eclipse.cdt.managedbuilder.internal.core.ResourceConfiguration
	at com.qnx.tools.ide.qde.managedbuilder.core.QCCCommandLineGenerator$1.calculateTarget(QCCCommandLineGenerator.java:39)
	at com.qnx.tools.ide.qde.managedbuilder.core.QCCCommandLineGenerator$1.getFlags(QCCCommandLineGenerator.java:73)
	at org.eclipse.cdt.managedbuilder.ui.properties.ToolSettingsPrefStore.getString(ToolSettingsPrefStore.java:161)
	at org.eclipse.cdt.ui.newui.MultiLineTextFieldEditor.doLoad(MultiLineTextFieldEditor.java:255)
	at org.eclipse.jface.preference.FieldEditor.load(FieldEditor.java:496)
	at org.eclipse.cdt.managedbuilder.ui.properties.BuildToolSettingUI.updateFields(BuildToolSettingUI.java:593)
	at org.eclipse.cdt.managedbuilder.ui.properties.BuildToolSettingUI.setValues(BuildToolSettingUI.java:599)
	at org.eclipse.cdt.managedbuilder.ui.properties.ToolSettingsTab.displayOptionsForTool(ToolSettingsTab.java:243)
	at org.eclipse.cdt.managedbuilder.ui.properties.ToolSettingsTab.handleOptionSelection(ToolSettingsTab.java:383)
	at org.eclipse.cdt.managedbuilder.ui.properties.ToolSettingsTab.updateData(ToolSettingsTab.java:596)
	at org.eclipse.cdt.managedbuilder.ui.properties.ToolSettingsTab.setVisible(ToolSettingsTab.java:273)
	at org.eclipse.cdt.ui.newui.AbstractCPropertyTab.handleTabEvent(AbstractCPropertyTab.java:507)
	at org.eclipse.cdt.ui.newui.AbstractPage.setVisible(AbstractPage.java:590)
	at org.eclipse.jface.preference.PreferenceDialog.showPage(PreferenceDialog.java:1278)
	at org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.showPage(FilteredPreferenceDialog.java:433)
	at org.eclipse.jface.preference.PreferenceDialog$9.selectionChanged(PreferenceDialog.java:698)
	at org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredViewer.java:842)
	at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
	at org.eclipse.core.runtime.Platform.run(Platform.java:857)
	at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
	at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:199)
	at org.eclipse.jface.viewers.StructuredViewer.firePostSelectionChanged(StructuredViewer.java:840)
	at org.eclipse.jface.viewers.StructuredViewer.setSelection(StructuredViewer.java:1642)
	at org.eclipse.jface.viewers.TreeViewer.setSelection(TreeViewer.java:1095)
	at org.eclipse.jface.preference.PreferenceDialog.selectSavedItem(PreferenceDialog.java:1009)
	at org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.selectSavedItem(FilteredPreferenceDialog.java:476)
	at org.eclipse.jface.preference.PreferenceDialog$4.run(PreferenceDialog.java:369)
	at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:67)
	at org.eclipse.jface.preference.PreferenceDialog.createContents(PreferenceDialog.java:365)
	at org.eclipse.jface.window.Window.create(Window.java:426)
	at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1081)
	at org.eclipse.ui.internal.dialogs.PropertyDialog.createDialogOn(PropertyDialog.java:81)
	at org.eclipse.ui.dialogs.PropertyDialogAction.createDialog(PropertyDialogAction.java:175)
	at org.eclipse.ui.dialogs.PropertyDialogAction.run(PropertyDialogAction.java:154)
	at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
	at...
Re: IDE managed build error
Thank you for the problem reporting. It has been addressed and will be
included into upcomeing integration build.
get the following:
> Build error
> !STACK 0
39)
> 	at...
Integration build is posted, see http://community.qnx.com/sf/wiki/do/viewPage/projects.ide/wiki/WhatIsNewIn4.5.1
point.
get the following:
> Build error
> !STACK 0
39)
> 	at...
Awesome...thanks
Kevin
