Forum Topic - C Project vs. QNX C Proj: (4 Items)
Could somebody please provide a quick summary of C Projects vs. QNX projects in 4.5, and what the anticipated different
usages would be?
Why is the Standard make project gone in 4.5?  I assume that the 'C Project' is it's replacement?
If a developer using the IDE wanted to share their project with a developer who preferred command line tools, would one
project be preferable to the other?
--Chris Foran
Re: C Project vs. QNX C Proj
Gossips about regular make project passing away could not be confirmed
by any reliable source :-) You still can create it using  C or C++
wizard. Having on your screen the first wizard panel, select in the left
tree Makefile project and Empty project. THen on the right panel select
QNX QCC toolchain and press finish. You can also press  Next instead of
Finish and in the following panel press button Advanced Setting, then
select C/C++ Build and pre-set build target properties and and other
parameters. This is almost the same as Set QNX Environment action in
oprevious release. It can be also done later via properties dialog.
Anyway finally you'll get new empty regular make project. Unfortunately,
we were very limited now by  CDT 4 as well as in tyme and work force, so
I'm not very happy with   this solution. However, I'm sure that wewill
improve usability dramaticallyt in the next release.
I know for sure that the question about MBS and QNX builders whas been
already addressed in this forum by Elena, but I was unlucky trying to
find this thread. Briefly, MBS and QNXp projects are both managed
projects. QNX project as you can see from its name is QNX oriented  and
based on recoursive make files (which means it to be very useful for
multi-platform defelopment). I would mention two features of MBS build
system: First,  it's  its  flexibility: it can be used for various tool
chains (QNX supports only qcc and intel) if appropriate toolchain
definition added to xml  descripting file). Second, beside make-based
builder MBS has its own internal builder which in perspective (not now,
don't be afraid) should completely replace make builder. However, in my
opinion (and not only my)  it is too early to do it
Don't hesitate to ask more if it is "too brief" for you.
Alex
different usages would be?
one project be preferable to the other?
> Thanks,
> --Chris Foran
> http://community.qnx.com/sf/go/post13372
Thanks for the reply Alex.
I am attempting to follow your suggested steps to create the equivalent of a standard make project, and I'm having
trouble.
I create a new C project-->Makefile project-->empty project-->finish
Then I simply pasted a helloworld.c and a Makefile into the project.  Then, right click-->build project.
What I'm getting is below.  What is pch_support?  Why is it trying to build with coverage?  I'm just using defaults, and
 my makefile doesn't have any coverage options.
**** Build of configuration Generic/QNX for project t4 ****
make all
qcc -g -Vgcc_ntox86 -w9  -g -Vgcc_ntox86  hello.c   -o hello
C:\QNX640\host\win32\x86\usr\bin\ntox86-ld: %(ftest-coverage:-lgcov): No such file: No such file or directory
cc: ignoring unknown option 'pch_support'
cc: C:/QNX640/host/win32/x86/usr/bin/ntox86-ld caught signal 1
make: *** [hello] Error 1
trouble.
and my makefile doesn't have any coverage options.
The 632 qcc is not able to parse the 640 conf files. Make sure the 640
qcc is being called.
If the underlying compiler has support for pre-compiled headers, the qcc
conf files will be have the pch_support option set because the driver
needs to know how far along in compilation stage to go, and what files
to produces.
The second part is that it is not trying to build with code coverage.
The new conf files have a gcc 'spec'-like syntax to allow the conf files
to use rules so if the user specifies one option it will imply another.
In this case the rule is if you specify -ftest-coverage, it will
automatically link in the code coverage library (libgcov).
Ryan Mansfield
