Trackers
Trackers
Forum Topic - IDE Photon project fails with 'Can't Open: "Icon.wgti": (3 Items)
Hi, I am using photon for the first time and after creating a new IDE Photon project an error dialog appears saying:
"PhAB: Can't Open: "Icon.wgti". Please resolve the problem and re-try this operation. (No such file or directory)"
I have check the info by Google while there is a possible solution in http://www.qnx.com/support/knowledgebase.html?id=
50130000000my79.
saying:This is a known issue where the IDE does not create the Icon.wgti files. To address this error run the Generate
UI command from the Phab menu.
Build -> Generate UI
However after that was run and the project has been saved another Dialog appears saying:
command 'approto -p *.c *.cc *.cpp *C >proto.h' died(127)
which is different from what shows in the  http://www.qnx.com/support/knowledgebase.html?id=50130000000my79.
"Command '$QNX_HOST/usr/photon/bin/sort -u -oC:/ide-4.7-workspace/pt3/src/abWfiles.t C:/ide-4.7-workspace/pt3/src/
abWfiles.t' failed (2)"
Would you please help me to fix the problem ?
Re: IDE Photon project fails with 'Can't Open: "Icon.wgti"
I have exactly the same problem.
I tried to create cygwin and cygwin/tmp in C driver, it doesn't work.
Please anybody help ??
同样遇到这种问题   头疼
