RE: QNX IDE compile error when cygwin window open on my machine
07/23/2010 1:37 PM
post60464
Hi Christian,
Please see the compile errors below. Using cygcheck, it looks like I am using cygwin 1.5.25-15.
If I close the cygwin shell, the compile works fine. If I have a cygwin shell open the QNX tools fail to compile.
make[5]: Entering directory `C:/qnx-workspace/bsp-vendor.testchip-src/src/hardware/devc/sertestchip/arm'
make -j 1 -Cle -fMakefile install
make[6]: Entering directory `C:/qnx-workspace/bsp-vendor.testchip-src/src/hardware/devc/sertestchip/arm/le'
C:/QNX641/host/win32/x86/usr/bin/qcc -Vgcc_ntoarm -c -O -Wc,-Wall -Wc,-Wno-parentheses -Wc,-fno-builtin -DNDEBUG -I. -
IC:/qnx-workspace/bsp-vendor.testchip-src/src/hardware/devc/sertestchip/arm/le -IC:/qnx-workspace/bsp-vendor.testchip-
src/src/hardware/devc/sertestchip/arm -IC:/qnx-workspace/bsp-vendor.testchip-src/src/hardware/devc/sertestchip -IC:/qnx-
workspace/bsp-vendor.testchip-src/src/hardware/devc -IC:/qnx-workspace/bsp-vendor.testchip-src/src/hardware/devc/../../.
./install/usr/include/xilinx -IC:/qnx-workspace/bsp-vendor.testchip-src/src/hardware/devc/../../../install/usr/include -
IC:/QNX641/target/qnx6/usr/include -EL -DVARIANT_le -DVARIANT_sertestchip -DBUILDENV_qss C:/qnx-workspace/
bsp-vendor.testchip-src/src/hardware/devc/sertestchip/externs.c
In file included from C:/qnx-workspace/bsp-vendor.testchip-src/src/hardware/devc/sertestchip/externs.c:25:
C:/qnx-workspace/bsp-vendor.testchip-src/src/hardware/devc/sertestchip/externs.h:46:26: error: arm/typedefs.h: No such
file or directory
make[6]: Leaving directory `C:/qnx-workspace/bsp-vendor.testchip-src/src/hardware/devc/sertestchip/arm/le'
make[5]: Leaving directory `C:/qnx-workspace/bsp-vendor.testchip-src/src/hardware/devc/sertestchip/arm'
make[4]: Leaving directory `C:/qnx-workspace/bsp-vendor.testchip-src/src/hardware/devc/sertestchip'
make[3]: Leaving directory `C:/qnx-workspace/bsp-vendor.testchip-src/src/hardware/devc'
make[2]: Leaving directory `C:/qnx-workspace/bsp-vendor.testchip-src/src/hardware'
make[1]: Leaving directory `C:/qnx-workspace/bsp-vendor.testchip-src/src'
C:/qnx-workspace/bsp-vendor.testchip-src/src/hardware/devc/sertestchip/externs.h:47:31: error: arm/testchip_uart.h: No
such file or directory
cc: C:/QNX641/host/win32/x86/usr/lib/gcc/arm-unknown-nto-qnx6.4.0/4.3.3/cc1 caught signal 1
make[6]: *** [externs.o] Error 1
make[5]: *** [install] Error 2
make[4]: *** [install] Error 2
make[3]: *** [install] Error 2
make[2]: *** [install] Error 2
make[1]: *** [install] Error 2
make: *** [install] Error 2
Scott
From: Christian Damus [mailto:community-noreply@qnx.com]
Sent: July 23, 2010 9:57 AM
To: general-ide
Subject: Re: QNX IDE compile error when cygwin window open on my machine
Hi, Scott,
Can you be more specific about the nature of this conflict between cc1
and cygwin? It is my understanding that cc1 is not a cygwin executable;
it's "pure Windows."
What error messages are you seeing on the console?
How many versions of cygwin do you have installed? Are you perchance
using the cygwin environment that is bundled with the Photon
AppBuilder? I ask because this only seems likely if you are attempting
to load multiple versions of the cygwin DLL, which could conflict.
Other users report no problems using cygwin with this and SDP release.
Cheers,
Christian
On 22/07/10 06:37 PM, Scott Branden wrote:
> I am running QNX Momementics 4.6.0 from the QNX 6.4.1 software development suite.
> I am compiling the code on a Windows XP machine.
> An ARM BSP fails to compile when I have a cygwin shell open (cygwin is already installed on this machine and used for
other purposes). The CC1 compile that comes with QNX fails to find files due to some sort of conflict with an open
cygwin window. As soon as I exit the cygwin shell I am able to compile in QNX again.
> Any ideas how to fix this incompatibility?
08/03/2010 8:40 PM
post61493
Hi Christian,
Any word on how to make QNX not conflict with existing cygwin installed on my PC?
Scott
