Forum Topic - Can't install IDE 4.5: (5 Items)
Hi,evryone!
   First , I install  a IDE 4.6,but now I want to install a IDE 4.5,so I  uninstall the
IDE 4.6 and install the IDE 4.5.as a result ,I can't install the IDE 4.5 ,there are some errors.Please give me some
idles ,thanks!
Re: Can't install IDE 4.5
What errors did you see when you tried to install IDE 4.5 - I assume you
meant QNX SDP 6.4.0?
Reply-to: post49154@community.qnx.com
To: general-ide <post49154@community.qnx.com>
Subject: Can't install IDE 4.5
Date: Wed, 10 Mar 2010 07:33:55 -0500 (EST)
Hi,evryone!
idles ,thanks!
Thanks for your answer,you are right,I meant the  QNX SDP 6.4.0,before I uninstall the QNX SDP 6.4.1,but I can't install
 the lower version SDP 6.4.0,it has the tip:you have install the IDE,you can't install.   Looking for  your answer,
thanks!
There are steps you can do to clean up your previous 6.4.1 SDP installation:
1) If you don't have other QNX SDP version installed, you can remove a file called "vpd.properties". For Windows you can
 find it under <WINDOWS_SYSTEM_ROOT>/vpd.properties, for Linux you can find it under <ROOT_HOME_DIR>/vpd.properties
2) If you have other QNX SDP version installed and you want to keep those installation meta-data, you have to search for
 string "6.4.1" in the vpd.properties file and delete all lines with that string.
Last thing although not required, check you "QNX_HOST" and "QNX_TARGET" environment variables. If  they point to "6.4.1"
 then either change them or remove the two variables from your environment.
If the above steps do not fix your problem, please attach your installation log file to this post. You can find the log
file under the root directory of your system drive (for Windows C:\, for Linux /)
BTW why do you need install a previous SDP?
HTH,
Andy
Thanks for your answer,because I need to use "mmedia-core-1.1.0-20083051025-win32.exe ",I can't download the higng
version of mmedia-core,so I have to instal the lower version of IDE,so as to use the mmedia-core-1.1.0.
