Forum Topic - Managing projects: (2 Items)
Managing projects
I am trying to manage some projects within the IDE workspace.
I thought I could handle them through Container projects, but this doesn't seem to be as easy as I thought.
For example, each of my projects will contain a QNX-C-Project named IPC. The problem now is, that the different customer
-projects will all contain this IPC, but in different versions, branches etc.
I now think I need to set up a complete working space for each customer-project, or is there a better way? Whenever I
create a new Workspace, I need to adjust all settings (i.e. Syntax-Highlighting, Indexer Settings, ...) from scratch.
Isn't there a way to set up a Workspace from a "template"?
This would make it quite easy then to handle the different customer-projects.
Christian
Re: Managing projects
Hi, Christian,
Workspaces are generally quite portable.  I, myself, like to apply the same settings in all of my workspaces, for
different roles and different branches.  The way that I do it is to create an empty workspace as a template and
configure all of my preferences, including workbench layout, compiler settings, source repositories, task/bug
repositories, etc.  I don't create any projects in the workspace.
Then, I archive the .metadata folder in a ZIP file or some such.  Any time I want to create a new workspace, I just
create a folder and unarchive the .metadata into it.  Then, it's ready to go.
Note, also, that you can check out as many branches of the same project as you need in a single workspace, if you like.
 Just check them out into different-named projects (e.g., IPC_trunk, IPC_m5, etc.) and set the NAME variable in the
common.mk of each to the same logical project name ("IPC" in your case).  You can do that in the "QNX C/C++ Projects"
property page, in the "General" tab.  Two things to note with this approach, though:  (a) it is slightly awkward if the
.project file is maintained in source control, as the method relies on changing the name of the project on check-out;
(b) any dependencies on the project from other projects would have to use the local workspace names (branch-encoded) of
the projects, which isn't so nice if those dependent projects are shared (the names would end up in their common.mk, for
 example).
Overall, your best strategy is probably to use a different workspace for each branch.  It's easiest to stay out of SCM
trouble that way.
HTH,
Christian
customer-projects will all contain this IPC, but in different versions, branches etc.
	Christian
	General
	http://community.qnx.com/sf/go/post47470
Christian W. Damus
Software Developer, IDE Team
QNX Software Systems <http://www.qnx.com/>;
