Re: Debug Source Display error
11/27/2009 12:07 PM
post42771
hmmm, those projects are not even related. I tried opening all projects now, but the error still occurs. Can I remove
the dependencies somehow?
!ENTRY org.eclipse.ui 4 0 2009-11-27 18:09:25.250
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.IllegalArgumentException: Path must include project
and resource name: /qnxWorkspace)
at org.eclipse.swt.SWT.error(SWT.java:3777)
at org.eclipse.swt.SWT.error(SWT.java:3695)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:136)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3425)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2348)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2200)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:288)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:490)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:193)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:386)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
Caused by: java.lang.IllegalArgumentException: Path must include project and resource name: /qnxWorkspace
at org.eclipse.core.runtime.Assert.isLegal(Assert.java:64)
at org.eclipse.core.internal.resources.Workspace.newResource(Workspace.java:1634)
at org.eclipse.core.internal.resources.Container.getFile(Container.java:123)
at org.eclipse.ui.part.FileEditorInputFactory.createElement(FileEditorInputFactory.java:61)
at com.ibm.rational.rhapsody.platformintegration.ui.editors.RhpDiagramEditorInputFactory.createElement(Unknown Source)
at org.eclipse.ui.internal.NavigationHistoryEditorInfo.restoreEditor(NavigationHistoryEditorInfo.java:79)
at org.eclipse.ui.internal.NavigationHistory.addEntry(NavigationHistory.java:368)
at org.eclipse.ui.internal.NavigationHistory.markLocation(NavigationHistory.java:211)
at org.eclipse.ui.texteditor.AbstractTextEditor.markInNavigationHistory(AbstractTextEditor.java:6053)
at org.eclipse.ui.texteditor.AbstractTextEditor.selectAndReveal(AbstractTextEditor.java:6017)
at org.eclipse.ui.texteditor.AbstractTextEditor.selectAndReveal(AbstractTextEditor.java:5997)
at org.eclipse.debug.internal.ui.sourcelookup.SourceLookupFacility.positionEditor(SourceLookupFacility.java:317)
at org.eclipse.debug.internal.ui.sourcelookup.SourceLookupFacility.display(SourceLookupFacility.java:241)
at org.eclipse.debug.ui.DebugUITools.displaySource(DebugUITools.java:776)
at org.eclipse.debug.internal.ui.elements.adapters.StackFrameSourceDisplayAdapter$SourceDisplayJob.
runInUIThread(StackFrameSourceDisplayAdapter.java:155)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:94)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at...
