Forum Topic - SystemProfiler - Address Translation - process to binary binding: (5 Items)
I was testing different versions of a binary that is instrumented with -finstrument-functions.
For each test I did a kernel trace that I wanted to analyse using "Address Translation" feature.
Due to my build and target environment the binary had allways the same name.
So with this I run into the "problem" that I once had completely wrong translations.
I found that this was because the process name and the k-trace name were the same as of a previous run, but binary
contents had changed.
After clearing Addr.Trans cache things were fine.
But this led me to a thing I already wanted to have in the past.
Currentley Addr.Trans. is only working if the process name is the same as the binary name I have on my host machine.
Why not adding the possibilty to have an explicit mapping, in the way that I can tell the translator use this binary for
 a specific process X, without the need of having equal names?
any suggestions?
/hp
Re: SystemProfiler - Address Translation - process to binary binding
Funny you should just bring this up, as it has been on my mind too. We've had a few people lately that have had issues
with Address Translation because of mismatched process/binary name (especially prevalent if you don't disable use unique
 name on the c/c++ launch configuration).
I'm raising a feature request to allow users to map binaries defined in address translation to processes in their trace
file. We already have a feature request to warn users when they have specified a binary for address translation and no
matching process is found when they open their trace file.
Wouldn't it be useful to have an option that when you open a new logfile,
it auto-populates a list of binaries that have address translation possible,
and allows you to vet it's suggested path to the binary?
unique name on the c/c++ launch configuration).
trace file. We already have a feature request to warn users when they have specified a binary for address translation
and no matching process is found when they open their trace file.
> http://community.qnx.com/sf/go/post41060
cburgess@qnx.com
AW: SystemProfiler - Address Translation - process to binary binding
+1
>Von: Colin Burgess [mailto:community-noreply@qnx.com]
>Gesendet: Freitag, 30. Oktober 2009 15:10
>An: general-ide
>Betreff: Re: SystemProfiler - Address Translation - process to
>binary binding
>new logfile, it auto-populates a list of binaries that have
>address translation possible, and allows you to vet it's
>> General
>cburgess@qnx.com
>General
>http://community.qnx.com/sf/go/post41062
Definitely. I think we could incorporate both sets of functionality in a single dialog.
It would help to make address translation easier to discover as well. It has improved now that you can set values along
with your launch configuration, but it's not intuitive to have to dig into the properties of the trace file to tweak
these values when they aren't set properly for your trace.
