Re: How to reference header/libs external to workspace using
environment variables
10/01/2009 11:49 AM
post39209
Hi, Glenn,
It's not obvious, but it's easy to do.
Just browse your local filesystem using the "Disk..." button to add the
include path. Then, click on the path in the list to start editing it.
Replace the portion (usually the leading bit) that corresponds to your
environment variable in the usual make syntax. e.g.,
$(MY_INCLUDE_ROOT)/some/include/folder
HTH,
Christian
On Thu, 2009-10-01 at 11:41 -0400, Glenn Schmottlach wrote:
> My source control system pulls down shared libraries (and their associated headers) somewhere outside my Momentics
workspace.
> Now, I would like to create a QNX C/C++ project that utilizes those shared header files and libraries. So I create
this project and go to the project's properties to configure the extra include (and library) search paths to reference
those paths outside the Momentics workspace. Unfortunately, the GUI only allows you to either select another project's
path, a QNX target path, or an absolute path somewhere on your target file system.
> What I really want to be able to do is *export* my Momentics project and check-in the exported project into my source
control tool. Since the header/library paths are hard-coded to a path on my development machine, anyone who wants to
import this project into their workspace must edit these paths by hand in order to reference the dependencies on their
PC. So, ideally, I want to be able to use environment variables in the configurations paths and have those resolved at
compile time. I know the regular CDT C/C++ projects allow you to select environment variables and include those in your
paths. Is this possible to do with QNX C/C++ projects? Until now it doesn't appear to be supported in 4.6. Is there a
work-around available.
> Please note that I would assume any necessary environment variables used in a path would be defined in the environment
PRIOR to launching Momentics.
> Any solution would be appreciated. . .
> http://community.qnx.com/sf/go/post39208
