How to load images with .img format in Phab?
09/25/2009 10:09 AM
post38757
Hello everyone,
I need to load some medical images with .img format in my application. But the PxLoadImage() just can load like .jpeg,.
bmp,.tif.pcx....not .img format. The .img file I used is a file contain many slices of MRI images, each slice is a 256*
256 pixel image. So I intend to read the .img file first and PhCreateImage() and PdDrawImage(). My code is:
Code:
unsigned int fbuffer[256][256] = { 0 };
PhPoint_t p = { 300, 0 };
PhDim_t pp = {512, 512 };
static unsigned int slice[150][256][256]={0};
int rc,i,j,n;
FILE* fp;
PhImage_t *img;
PgColor_t plat;
char *bits;
fp=fopen("/root/jack/dcs.img","r");
if( fp == NULL )
PtTextModifyText(ABW_inf_text, 0,0,-1,"rom file open failed",20);
for (i=0;i<150;i++)
//rc=fread(fname, 1, sizeof(fname), fp);
rc=fread(fbuffer, 256, 256, fp);
}/*finally, fbuffer should be the 150th slice of image 256*256*/
img=PhCreateImage(NULL,512,512,Pg_IMAGE_DIRECT_1555,NULL,0,1);
/* bits=img->image;
for (i=0;i<256;i++,bits+=img->bpl)
for (j=0;j>256;j++)
((short*)bits)[j]=fbuffer[i][j];*/
PgSetPalette( img->palette, 0, 0, img->colors, Pg_PALSET_SOFT, 0 );
PgDrawImage( fbuffer, img->type, &p, &img->size, img->bpl, 0 );
Any thing wrong with the code please? And at the end, I draw the 150th MRI image with the array fbuffer, I try to write
the data in fbuffer to the pointer img->image, but I cannot write in. Can anybody tell me how to write in?
And the image shows un-complete like lost data or maybe have offset, what is the reason? Maybe because I didnot write
the data into img->image??
Please help, thank you very much!
Jason
Re: How to load images with .img format in Phab?
09/25/2009 1:46 PM
post38800
Here is an outline of what you need to done to get your image in a photon widget:
- Creating your photon image base on the data in the img file
-- Choose an appropriate format when calling calling PgCreateImage()
-- “fill-up” the created image with the data based on the raw img data. You need to know the format of the raw img
data. Extract the color/index value of at an x,y from the raw img data, and use the PiSetPixel(..x,y..) on the photon
image to set it. Do this for all pixels.
-- (NOTE: When using direct images types you don’t need to set palette)
- Rendering options:
-- PtLabel – use your image as Pt_ARG_LABEL_IMAGE, the label will take care of the rest and display the image for you
-- PtRaw – you will need to write your own render function in which you will do PgDrawImage() with your image
09/28/2009 8:15 AM
post38851
> widget:
> need to know the format of the raw img data. Extract the color/index value of
Thank you very much Misha, I got the image.
Now, I need to get the coordinate (x,y) of a point on the image, like press the left mouse button, then the coordinate
is recorded. I knew this should use a event handler, but how to read the coordinate from the image??
Actually, I draw the image in a raw widget, and I can get the left up corner and the right down corner, and the image is
drawed begin with the left up corner, I should read the cooedinates base on the raw widget or the image directly?
Many thanks in advance!
09/28/2009 9:24 AM
post38860
You need to attach a raw event handler the raw widget with the Ph_EV_BUT_PRESS mask. When an event of this type arrives,
your callback will be called. You should use PhGetRects() to obtain the pointer’s position. The event translation is
relative to your canvas, since you render the image yourself, and (unless you changed it) the image’s position is
relative to the widget’s origin. You can translate the pointer event rectangle to be relative to the widget’s origin:
PhTranslateRect( event_rect, &canvas.ul );
Now you can subtract the image position from the event position and will get a rectangle relative to your image:
PhDetranslateRect( ev_rect, &image_pos ); If the ev_rect.ul is negative or ev_rect.lr is greater than image dimensions
your are outside the image.
The event's docs: http://www.qnx.com/developers/docs/6.4.0/photon/prog_guide/events.html
09/28/2009 10:54 AM
post38875
> mask. When an event of this type arrives, your callback will be called. You
> translation is relative to your canvas, since you render the image yourself,
> and (unless you changed it) the image’s position is relative to the widget’s
> widget’s origin: PhTranslateRect( event_rect, &canvas.ul );
> rectangle relative to your image: PhDetranslateRect( ev_rect, &image_pos ); If the
> ev_rect.ul is negative or ev_rect.lr is greater than image dimensions your are
> outside the image.
> events.html
Thanks, I got it with PhPointerEvent_t, but the coordinate is Integer, can it be more precise? If not, it's ok, no big
effect.
One more question about the image, the image shows in blue color now with black backgroud, how can I change blue to gray
? PgGray()??It's not working...
Many thanks and regards,
09/28/2009 11:00 AM
post38878
Coordinates are shorts.
I guess you didn't set background color or image format correctly -- the "background" of your image is filled in by you
after all. The widget background color is rendered (usually) by the PtSuperClassDraw() call in the draw function.
09/28/2009 11:34 AM
post38885
> background" of your image is filled in by you after all. The widget background
> function.
How to fill the "background" color? The image is two bytes per pixel so I choose image direct format like:
PhCreateImage(NULL,256,256,Pg_IMAGE_DIRECT_1555,NULL,0,1);
PtSuperClassDraw() is used in the draw function as well. But I don't know the image format is correct or not, but it
works fine except the color. I tried every format actually.
09/28/2009 11:56 AM
post38886
Something is missing, please post the code.
What is the format of your img data?
09/28/2009 12:16 PM
post38889
The format is Unsigned short, the code is below,
Thank you very much!
/* Standard headers */
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
/* Local headers */
#include "ablibs.h"
#include "abimport.h"
#include "proto.h"
#include <malloc.h>
#include <assert.h>
#include <ctype.h>
#include <signal.h>
#include <Ph.h>
#include <Pt.h>
#include <photon/PxImage.h>
void raw_draw_f( PtWidget_t *widget, PhTile_t *damage )
unsigned short fbuffer[256][256] = { 0 };
int rc,i,j,n;
FILE* fp;
PhImage_t *img,*img1;
PhPoint_t p = { 0, 0 };
double num=0;
PtSuperClassDraw( PtBasic, widget, damage );
PhRect_t raw_canvas;
PtCalcCanvas (ABW_raw, &raw_canvas);
num=raw_canvas.ul.x;
fp=fopen("/root/jack/dcs.img","rb");
if( fp == NULL )
for (i=0;i<75;i++)
rc=fread(fbuffer,2,256*256, fp);
PgSetDrawBufferSize( 0x8000 );
if ((img=PhCreateImage(NULL,256,256,Pg_IMAGE_DIRECT_1555,NULL,0,1))!=NULL)
PtTextModifyText(ABW_inf_text, 0,0,-1,"11",2);
if(PiSetPixel(img,0,0,fbuffer[0][0])==0)
for(j=0;j<256;j++)
for(n=0;n<256;n++)
PiSetPixel(img,j,n,fbuffer[j][n]);
//img->colors=PgGray(160);
PgDrawImage(img->image, img->type, &raw_canvas.ul, &img->size, img->bpl, 0 );
PtSetResource (ABW_m1, Pt_ARG_NUMERIC_VALUE, &num, 0);
//PtSetResource (ABW_m2, Pt_ARG_NUMERIC_VALUE, 1, 0);
//PgWaitDrawComplete();
09/28/2009 12:30 PM
post38891
Ok, each pixel requires 16 bits, but what is the content?
For example, the format ARGB1555 defines:
1 bit - pixel for alpha,
5 bits -- red, 5 bits -- green, 5 bits -- blue, and it also defines a packing order.
What is the packing order of the img data inside the short?
09/28/2009 12:49 PM
post38897
> order.
Sorry, I don't know the packing order, I cannot find it in the reference, I need ask someone else. Do you mean that if
the packing order is 4 bit - pixel for alpha,
4bits -- red, 4 bits -- green, 4bits -- blue, then the format should be
ARGB4444? The format needs to be chosen according to the packing order.
09/28/2009 12:55 PM
post38899
Yes, that is what I mean. If photon image doesn't support what img data has, you will need to decypher the img data and
fill up the destination image with the proper data.
09/28/2009 12:58 PM
post38901
> you will need to decypher the img data and fill up the destination image with
> the proper data.
Understood, thank you very much for your help and patience!
