Forum Topic - Poulsbo and screen resiolution: Page 1 of 2 (27 Items)
On my system (see attached get_hw_info) I'm using the devg-poulsbo.so as video driver.
http://www.qnx.com/developers/docs/6.4.1/neutrino/utilities/d/devg-poulsbo.so.html
It works fine with a resolution of 1024 x 768. But if I tried to set the resolution to 1280 x 1024 it failed and go back
 to 1024 x 768.
See all messages at the end of the sloginfo but the most important seems to be:
/usr/photon/bin/io-graphics: gf_dev_attach('/dev/io-display/8086,8108,0'): gf errno 2
Any idea why this error occurs?
Christophe
Attachment: Text hw-info-localhost_4.txt 58.28 KB
RE: Poulsbo and screen resiolution
Can you tell us what board this is and what type of display you are
using?
Can you exit to text mode and run 'show_vesa' and post the output?
From: Christophe Hannoyer [mailto:community-noreply@qnx.com]
Sent: January 15, 2010 11:43 AM
To: advanced-graphics
Subject: Poulsbo and screen resiolution
video driver.
bo.so.html
resolution to 1280 x 1024 it failed and go back to 1024 x 768.
to be:
Christophe
Advanced Graphics
http://community.qnx.com/sf/go/post45314
Re: RE: Poulsbo and screen resiolution
Thanks for the reply.
The board:
http://www.men.de/products/15MM01-.html
The display it's a BENQ FP91G+.
And the show_vesa is attached to this message.
Christophe Hannoyer
Attachment: Text show_vesa_1.txt 23.61 KB
The board:
Christophe Hannoyer
> -----Message d'origine-----
> De : Michael Van Reenen [mailto:community-noreply@qnx.com]
> Envoyé : lundi 18 janvier 2010 18:40
> À : advanced-graphics
> Objet : RE: Poulsbo and screen resiolution
> using?
> Thanks
> video driver.
> bo.so.html
> to be:
> Thanks,
> Christophe
> Advanced Graphics
> Advanced Graphics
> http://community.qnx.com/sf/go/post45412
I believe with this setup the driver will end up trying to use the video BIOS to set the graphics mode. (in particular
sDVO output likely to DVI or VGA)
The output of show_vesa lists 1024x768 but not 1280x1024 which is the issue.
Unfortunately with the current driver there is no way to override using of the BIOS.  We hope to address this in a
future release.
Sent: January 19, 2010 8:50 AM
Subject: RE: Poulsbo and screen resiolution
The board:
Christophe Hannoyer
> using?
> Thanks
> video driver.
> bo.so.html
> to be:
> Thanks,
> Christophe
> Advanced Graphics
> Advanced Graphics
Advanced Graphics
http://community.qnx.com/sf/go/post45470
Hello Michael,
Thank you for your reply.
Only to know you are involved in this driver development?
Anyway waiting for a new release fixing this I will also tried to see with the BIOS developer to know if he can fixed
this at the BIOS level.
We will see which of these two solutions will be available first.
Christophe Hannoyer
> Envoyé : mercredi 20 janvier 2010 03:45
> to set the graphics mode. (in particular sDVO output likely to DVI or VGA)
> BIOS.  We hope to address this in a future release.
I create an image with a small demo running Photon. I run this image without any problem on an Atom Z530. A customer is
using this image on an Atom Z510 and he get the error :
when starting io-graphics.
I attach to this post the show_vesa. I notice some difference with the previous I posted here but I don't know if thias
can explain that.
Any idea ?
Christophe
Attachment: Text show_vesa_2.txt 39.66 KB
RE: RE: Poulsbo and screen resiolution
What resolution and color depth are they trying to run at?
Mike
Sent: March 15, 2010 12:37 PM
Subject: Re: RE: Poulsbo and screen resiolution
without any problem on an Atom Z530. A customer is using this image on
gf_dev_attach('/dev/io-display/8086,8108,0'): gf errno 2 when starting
io-graphics.
previous I posted here but I don't know if thias can explain that.
Any idea ?
Christophe
Advanced Graphics
http://community.qnx.com/sf/go/post49496
Re: RE: RE: Poulsbo and screen resiolution
Hello Mike,
Thank you for the reply. They try to run at 1024x768 rgb565.
Christophe
> Thanks
> Mike
> Hello,
> io-graphics.
> Any idea ?
> Thanks,
> Christophe
> Advanced Graphics
Attachment: Text display.conf 302 bytes
RE: RE: RE: Poulsbo and screen resiolution
Does it work if they try settings refresh to 60?
Mike
Sent: March 16, 2010 4:43 AM
Subject: Re: RE: RE: Poulsbo and screen resiolution
Hello Mike,
Christophe
> Thanks
> Mike
> Hello,
> io-graphics.
> Any idea ?
> Thanks,
> Christophe
> Advanced Graphics
Advanced Graphics
http://community.qnx.com/sf/go/post49570
Re: RE: RE: RE: Poulsbo and screen resiolution
Test done at 60Hz and also with 800x600 and we always get the same problem.
Christophe
Any other suggestions?
Also at the end the customer want to use a display with 720x400, H=31.46kHz and V=70Hz
I assume this will not work if I look to the driver documentation. Is there any change to get this mode working?
Christophe
RE: RE: RE: RE: Poulsbo and screen resiolution
Thanks for the additional info.  It doesn't appear then that the failure
is caused by the same issue. (BIOS not providing the mode).   At this
time I can't say what may be the issue.
There is a pre-release version of our next release (6.5) available from
the QNX download site.  There is now an option that can be specified to
devg-poulsbo.so to try to directly configure the SDVO output (rather
than rely on the BIOS)
http://www.qnx.com/download/group.html?programid=20564
If you're able you may want to try this version/option to see if it
makes any difference.   At minimum you'd want this functionality to try
the 720x400 mode below (unless it happens to be in the video BIOS)
Sent: March 17, 2010 5:01 AM
Subject: Re: RE: RE: RE: Poulsbo and screen resiolution
problem.
H=31.46kHz and V=70Hz I assume this will not work if I look to the
Christophe
Advanced Graphics
http://community.qnx.com/sf/go/post49702
Re: RE: RE: RE: RE: Poulsbo and screen resiolution
Yes I can run test with 6.5 M8.
Can you please give me this option and all options supported by the driver? Because I don't found it with 'use devg-
poulsbo.so'.
Christophe
RE: RE: RE: RE: RE: Poulsbo and screen resiolution
The option in particular is 'directsdvo=1'.   The options are specified
and listed in the poulsbo.conf configuration file.   I believe this gets
installed to /usr/photon/config by default.
Sent: March 18, 2010 5:06 AM
Subject: Re: RE: RE: RE: RE: Poulsbo and screen resiolution
driver? Because I don't found it with 'use devg-poulsbo.so'.
Christophe
Advanced Graphics
http://community.qnx.com/sf/go/post49807
I run some test with 6.5 M8 and I didn't success to use this driver. When I install the system from the DVD when the
video should start I get nothing on the screen.
There is the possibility to try this version of the driver on 6.4.1 system?
Christophe
The 6.5 devg may not work on 6.4.1 due to some changes in symbols.
There was a problem found and recentlty fixed with the 6.5
devg-poulsbo.so that sounds like what you are seeing below.   A new
version of 6.5 (M9) is supposed to be posted soon I believe but don't
know the specific date so keep a look out at the download section.
Sent: March 31, 2010 4:35 AM
> from the QNX download site.  There is now an option that can be
> specified to devg-poulsbo.so to try to directly configure the SDVO
> output (rather than rely on the BIOS)
When I install the system from the DVD when the video should start I get
system?
Christophe
______________________________________________
Advanced Graphics
http://community.qnx.com/sf/go/post50906
Re: RE: RE: RE: RE: RE: Poulsbo and screen resiolution
> A new
I see on the download pages the M9 published the 31st March (the day before your last message). This is the one
including your last changes to this driver and that I can test?
Christophe
RE: RE: RE: RE: RE: RE: Poulsbo and screen resiolution
Yes - The driver in this posting should have the latest changes.
Sent: April 7, 2010 3:13 AM
Subject: Re: RE: RE: RE: RE: RE: Poulsbo and screen resiolution
> A new
before your last message). This is the one including your last changes
Christophe
Advanced Graphics
http://community.qnx.com/sf/go/post51248
I tried QNX 6.5 M9 but I'm still not able to set the redolution to 1280 x 1024.
I tried also to set 'directsdvo=1' but this don't help.
Here is what I tried after a normal installation of QNX 6.5 M9:
- login via telnet
# slay io-graphics
- Edit /etc/system/config/display.conf and add modeopts=/etc/system/config/poulsbo.conf
- (the file /etc/system/config/poulsbo.conf is the normal /usr/photon/config/poulsbo.conf with the option directsdvo=1)
# io-display -dvid=0x8086,did=0x8108
# ph
What else can I tried ?
Christophe
Below you indicate you slayed io-graphics - did you mean 'slay
io-display'?
If that's the case I don't know if there's anything else I can suggest
to easily try.   Is there any error messages in sloginfo?
Sent: April 26, 2010 1:29 PM
x 1024.
- login via telnet
# slay io-graphics
/usr/photon/config/poulsbo.conf with the option directsdvo=1) #
io-display -dvid=0x8086,did=0x8108 # ph
Christophe
Advanced Graphics
http://community.qnx.com/sf/go/post52798
> io-display'?
Yes it is. io-display and not io-graphics.
Nothing special in sloginfo :
Test @ 1024x768:
# slay io-display
# io-display -vv -dvid=0x8086,did=0x8108 -c /etc/system/config/display1024x768.conf
# vsync
Number of displays: 1
Display 0: 1024X768, refresh = 60Hz
Number of layers: 5
 --> here I get the application running on the display and I stop with Ctrl-C
# sloginfo -c
Dec 12 01:53:47    6     8     0 VGA primary : bus 0x0 dev/func 0x10
Dec 12 01:53:47    6     8     0 Found 1 PCI/AGP display devices
Dec 12 01:53:47    6     8     0 pci_init: found PCI device 8086:8108
Dec 12 01:53:56    6     8     0 Primary active: 0 10 7
Test @ 1280x1024:
# slay io-display
# io-display -vv -dvid=0x8086,did=0x8108 -c /etc/system/config/display1280x1024.conf
# vsync
gf_dev_attach() failed
# sloginfo -c
Dec 12 01:55:54    6     8     0 VGA primary : bus 0x0 dev/func 0x10
Dec 12 01:55:54    6     8     0 Found 1 PCI/AGP display devices
Dec 12 01:55:54    6     8     0 pci_init: found PCI device 8086:8108
Dec 12 01:55:56    6     8     0 Primary active: 0 10 7
Here you can see the vsync failed and nothing more in the sloginfo. Is there any way to make the poulsbo driver himself
more versbose?
Christophe
Unfortunately there is no additional debug information available with
the driver.
This is not an issue we've come across with systems here so to proceed
further you'll likely need to consult with your sales rep for options.
Sent: April 27, 2010 10:17 AM
> io-display'?
Test @ 1024x768:
# slay io-display
# vsync
Number of layers: 5
Ctrl-C # sloginfo -c
Test @ 1280x1024:
# slay io-display
# vsync
# sloginfo -c
there any way to make the poulsbo driver himself more versbose?
Christophe
Advanced Graphics
http://community.qnx.com/sf/go/post52892
> the driver.
Ok.
There is already the same system loan from your company in your local office. I don't know you have the opportunity to
run a short test on it. You can ask to Sönke Nielsen he know about that system.
If it's not possible then we will see later.
That you for the help and best regards,
Christophe
Unfortunately I'm located in our Canadian office.   It probably best for you to follow up with the local office to try
and escalate if this is an urgent issue.
Regards
Mike
Sent: April 30, 2010 3:50 AM
> the driver.
Ok.
Christophe
Advanced Graphics
http://community.qnx.com/sf/go/post53269
