Forum Topic - pidin in memory info: (12 Items)
I have 2 identical systems, both from HW and SW point of view.
One of them was booted on 31st Aug, the second one 11th Sept.
The "August" one shows "pidin in" memory information 19/63MB, the "September" one shows 25/63MB.
Could you find some explanation to this?
pidin shows the same list of processes, with almost the same memory sizes (some proceses are +/- 10kB).
Thanks, PKY
RE: pidin in memory info
Any files in /dev/shmem ?
> From: Pavol Kycina [mailto:community-noreply@qnx.com]
> Sent: September 16, 2009 7:38 AM
> To: ostech-core_os
> Subject: pidin in memory info
sizes
> Thanks, PKY
> http://community.qnx.com/sf/go/post38039
When you say almost the same memory sizes are you referring to the
output from "pidin mem"?  Also, what version are you using?
From: Alexander Koppel [mailto:community-noreply@qnx.com]
Sent: Wednesday, September 16, 2009 7:40 AM
To: ostech-core_os
Subject: RE: pidin in memory info
> To: ostech-core_os
sizes
> Thanks, PKY
OSTech
http://community.qnx.com/sf/go/post38040
Re: RE: pidin in memory info
pidin -f ncd
version 6.3.2 (on both systems)
> To: ostech-core_os
> > To: ostech-core_os
> sizes
> > Thanks, PKY
> > OSTech
RE: RE: pidin in memory info
Using pidin -f ncd doesn't show the whole picture, each thread has a
stack that also contributes to the total memory in use in the system.
Use "pidin mem"
Sent: Wednesday, September 16, 2009 9:48 AM
To: ostech-core_os
Subject: Re: RE: pidin in memory info
pidin -f ncd
> To: ostech-core_os
> > To: ostech-core_os
> sizes
> > Thanks, PKY
> > OSTech
OSTech
http://community.qnx.com/sf/go/post38053
Re: RE: RE: pidin in memory info
I have compared output from pidin mem from both systems.
These are the only differences:
Sept
  704549   1 bin/sh              10r REPLY            144K  108K  8192(516K)*
  360471   1 bin/login           10r REPLY             16K   72K  8192(516K)*
  315414   6 bin/io-net          10r RECEIVE           64K  476K   4096(68K)
  315414   5 bin/io-net          21r RECEIVE           64K  476K  4096(132K)
  315414   4 bin/io-net          10r RECEIVE           64K  476K   4096(68K)
  315414   3 bin/io-net          10r RECEIVE           64K  476K   4096(68K)
  315414   2 bin/io-net          10r RECEIVE           64K  476K  4096(132K)
  315414   1 bin/io-net          10r SIGWAITINFO       64K  476K  8192(516K)*
August
  835637   1 bin/login           10r REPLY             16K   72K  8192(516K)*
  835608   1 bin/login           10r REPLY             16K   72K  8192(516K)*
  761892   1 cpuLoad             10r NANOSLEEP         12K  104K   12K(516K)*
  368662   6 bin/io-net          10r RECEIVE           64K  516K   4096(68K)
  368662   5 bin/io-net          21r RECEIVE           64K  516K  4096(132K)
  368662   4 bin/io-net          10r RECEIVE           64K  516K   4096(68K)
  368662   3 bin/io-net          10r RECEIVE           64K  516K   4096(68K)
  368662   2 bin/io-net          10r RECEIVE           64K  516K  4096(132K)
  368662   1 bin/io-net          10r SIGWAITINFO       64K  516K  8192(516K)*
> Use "pidin mem"
> To: ostech-core_os
> pidin -f ncd
> > To: ostech-core_os
> > > To: ostech-core_os
> > sizes
> > > Thanks, PKY
> > > OSTech
> > OSTech
RE: RE: RE: pidin in memory info
You've accounted for 3.2M(pidin in might consider this to be 4M?) of the
6M in /dev/shmem(which doesn't show up in pidin -f ncd), and the
granularity of pidin in is 1M(I believe it rounds down) ...
Try the following to get a more accurate view of the memory in use:
#include <errno.h>
#include <stdint.h>
#include <unistd.h>
#include <stdarg.h>
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <sys/stat.h>
#include <sys/syspage.h>
uint64_t
get_free_mem (void)
        int ret;
        struct stat64 sbuf;
        ret = stat64("/proc", &sbuf);
        if (ret == -1) {
                printf("stat(/proc) failed: %s", strerror(errno));
        return sbuf.st_size;
uint64_t
get_total_mem (void)
        char *str = SYSPAGE_ENTRY(strings)->data;
        struct asinfo_entry     *as = SYSPAGE_ENTRY(asinfo);
        uint64_t total = 0;
        unsigned num;
        for (num = _syspage_ptr->asinfo.entry_size / sizeof(*as); num >
0; --num) {
                if(strcmp(&str[as->name], "ram") == 0) {
                        total += as->end - as->start + 1;
                ++as;
        return total;
int
main (int argc, char **argv)
        uint64_t free_mem = get_free_mem();
        uint64_t total_mem = get_total_mem();
        printf("FreeMem/TotalMem: %llu/%llu\n", free_mem,total_mem );
        printf("Total Mem In Use: %llu bytes\n",total_mem-free_mem );
        return EXIT_SUCCESS;
Sent: Wednesday, September 16, 2009 2:58 PM
To: ostech-core_os
Subject: Re: RE: RE: pidin in memory info
Sept
8192(516K)*
8192(516K)*
4096(68K)
4096(132K)
4096(68K)
4096(68K)
4096(132K)
8192(516K)*
August
8192(516K)*
8192(516K)*
12K(516K)*
4096(68K)
4096(132K)
4096(68K)
4096(68K)
4096(132K)
8192(516K)*
> Use "pidin mem"
> To: ostech-core_os
> pidin -f ncd
> > From: Alexander Koppel [mailto:community-noreply@qnx.com]...
Re: RE: RE: RE: pidin in memory info
I have run the program on both systems:
August:
18030592/66190336
48159744
Sept:
26337280/66190336
39853056
"pidin -p procnto mem" shows for code and data zero values for all threads, for stack it shows thread_1  0(320) and all
other threads 0(8182).
In 6.4.1 pidin shows non zero values for procnto. Is there any way to find out the real values of procnto in 6.3.2?
Thanks, PKY
[snip]
RE: RE: RE: RE: pidin in memory info
There was a bug in proc in 6.3.2, so there really isn't any way to tell
how much memory procnto is using...except to assume that all unaccounted
for memory is being used by proc ;-)
Sent: Thursday, September 17, 2009 1:34 AM
To: ostech-core_os
Subject: Re: RE: RE: RE: pidin in memory info
August:
18030592/66190336
48159744
Sept:
26337280/66190336
39853056
threads, for stack it shows thread_1  0(320) and all other threads
0(8182).
Thanks, PKY
the
[snip]
OSTech
http://community.qnx.com/sf/go/post38127
Re: RE: RE: RE: RE: pidin in memory info
How much memory should be used by proc?
Should it be constant, or can it grow over the time?
It seems to me, that proc is consuming more and more memory.
In 6.4.1 I have 3 identical systems which started with data segment size at about 2.5MB, one day later it was about 4.
5MB and today it was 6.5MB. I am just curios what that size will be tomorrow.  (Up to now I haven't found anything
suspicious in "pidin -f n[" output ... queues don't get bigger and bigger)
As there's no easy way to find info about proc memory usage in 6.3.2 I am just wondering if the difference I reported
between August and Sept system could be of the same type.
I will keep posting.
PKY
> To: ostech-core_os
> August:
> 18030592/66190336
> 48159744
> Sept:
> 26337280/66190336
> 39853056
> 0(8182).
> Thanks, PKY
> the
> [snip]
RE: RE: RE: RE: RE: pidin in memory info
The memory used by procnto depends(it can grow) on what you are doing in
your system.
Sent: Thursday, September 17, 2009 3:12 PM
To: ostech-core_os
Subject: Re: RE: RE: RE: RE: pidin in memory info
at about 2.5MB, one day later it was about 4.5MB and today it was 6.5MB.
found anything suspicious in "pidin -f n[" output ... queues don't get
bigger and bigger)
am just wondering if the difference I reported between August and Sept
PKY
tell
unaccounted
> To: ostech-core_os
> August:
> 18030592/66190336
> 48159744
> Sept:
> 26337280/66190336
> 39853056
> 0(8182).
> Thanks, PKY
> the
> [snip]
OSTech
http://community.qnx.com/sf/go/post38211
Yes, there are some files there:
output of "du -ks /tmp/ " for
August system: 10652
September system: 7409
the difference in /tmp/ is about 3MB, but in pidin it's 6MB
> > To: ostech-core_os
> sizes
> > Thanks, PKY
> > OSTech
